question about shifting on 03 sedan AT
Old Mar 27, 2008 | 10:33 PM
johannaccord1's Avatar
I got question about an 03 sedan. My old man just purchased a used 03 sedan AT. now my question, when ever I or he drives the car on tiptronic, when you up shift and stop, the little screen still says the previous gear(ex. from 1 to 4th gear and stop it will still be on fourth gear) but when you accelerate from stop it will actually change gear to fourth or where ever you left off. is this normal on sedans? thanks..
__________________
Old Mar 28, 2008 | 11:44 AM
nobody knows
Old Mar 28, 2008 | 11:48 AM
Boston's Avatar
I know when I stop, it automatically drops back into 1st. I'm in a coupe but the mechanics should be the same for the sedan. You say the display indicates the last gear but from a stop, I have to imagine you're back in 1st?
Old Mar 28, 2008 | 11:54 AM
Boston's Avatar
^ Gotcha and yes, mine is a 3.5. Thanks
Old Mar 28, 2008 | 11:58 AM
Jeff92se's Avatar
Red Card Crew
Normal for 03. When you go to MM, it goes to 4th. If at a light, that represents the highest gear it will shift into. Ie.. try going MM and shift into 3rd or 2nd. Then take off. Won't go any higher then your selected gear. Good for holding a gear though a corner etc.
__________________
Old Mar 28, 2008 | 01:13 PM
DaveB's Avatar
Originally Posted by HomieG35
You'll notice on 2003's that whenever you switch to MM (manual mode) it always displays 4th, whether you're in that gear or not. It will still shift as if in D, but when you get to the indicated gear, that gear will be held out. If you don't shift before redline in a 2003 it will shift at redline for you.
My 2003 sedan will bang off the limiter all day. It never upshifts until I do it.
Old Mar 28, 2008 | 02:14 PM
sliderg35's Avatar
+1 Me too. No auto-redline shifting here.
Old Mar 28, 2008 | 07:18 PM
my coupe down shifts on its own to 1st if I stop. I just thought that it would be the same for the sedan. but I guess its noraml for the sedans.
Old Mar 28, 2008 | 07:27 PM
Thanks for all the info fellas!
Old Mar 28, 2008 | 09:06 PM
codeflux's Avatar
i have 03.5 sedan, and mine does the same thing - the display shows 4th gear, even when you're stopped. the transmission will not shift past 4th gear, but will downshift - but the display does not change when it does. i have an early model 03.5 though, as it turned out - my ECU has the old-style plug.
Old Mar 28, 2008 | 09:45 PM
so it is normal right?
Old Mar 28, 2008 | 09:53 PM
Offtrac's Avatar
Mine acts the way you all described the 03.5 but its the downshifting thats annoying, mine wont downshift into a gear untill a safe speed is reached for that gear.... double edged sword i guess
