B&M shifter problems - getting returned
Old Apr 24, 2004 | 08:58 PM
rrowen's Avatar
Re: B&M shifter problems - getting returned
Wow, that sucks! Sorry to hear about your problems with the B&M shifter. Great write up for those who are thinking about buying one. I was waiting to hear responses from members who installed B&M. I'm glad I purchase the Rogue(months ago). Ya, the control socket is a bitch, cost more, but the quality is great and it is a better shifter than stock. At least you are getting your money back. Maybe hit B&M up (money) for your time it took to install, trying to make it work, and then having to reinstall your stock shifter!
'03c6mt/Blk/Premium/Sport/Aero
Eibach's/Hyper-Ground/Ztube+JWT/Injen SES
Rogue/Momo/Sparco
Old Apr 25, 2004 | 11:36 PM
dholly's Avatar
[note: here's a copy of my reply from FA]
Wow, these comments stand out like a sore thumb compared to my experience and the overwhelming number of positive reviews I have read! The positive user reviews are in this thread at my350z.com. There are 9 reviewed installs, with 8 of the 9 installs resulting in the following favorable comments:
Quote:
1.) I have driven Wld350Z's car with the B&M short shifter. Very awsum.. Like a Bolt Action Rifle - A little more Force - But Hand stays in nearly the same position.
2.) I just had the pleasure to drive and feel the shifter and it is incredible and smooth. This is a definate mod to get for me. I had a 3.5 altima with a mossy short shifter and this is wayyyyyy better than anything I've ever driven...Amazing product...
3.) The B&M Shifter is a great improvement over stock.. Butter smooth..
4.) man this is the absolute best 200 dollars i have spent!!!!!!!! they say it reduces the throw by 30% but i swear it seems like more....its almost just flicking your wrist to shift gears....put together well and it is great......shifts are very precise and crisp!!!!
5.) no noise or vibration at all....it is extreamly sturdy....man you cant go wrong with this thing i swear......i was amazed at this thing...very rugged and well built
6.) it really looks stock.....its about 1/2 inch shorter....the throw is enough that if you have it in 2nd 4th or 6th and looking into the car it almost looks to be in neutural....
7.) I installed mine took me about an hour. Went for a test drive. It is GREAT!!!!!!!!!!! Second gear is right there. You do have to get used to it. I think it's different from the stock one. Best 200 I spent. But no vibration or nothing.
8.) B&M Shifter... what can I say that hasn't already been said? Easily the best $200 I spent for an upgrade. If you enjoy a notchy shift this is your shifter. The gates are very clean and very precise. I have zero issues with reverse, however, 5th and 6th are a bit taller then I remember but not by much at all if any. Shifts are noticeably faster and more responsive. I think the 33% reduction is right on target. Again, this isn't an upgrade you should pass on if you are interested in really getting faster shifts. All and all I think the B&M was my favorite DIY upgrade. It was a bit challenging with the bolt underneth (not much room) and this is where I spent most of my time.
There was also one install that presented difficulties and these negative comments:
Quote:
I recieved mine earlier today(friday) and got it installed. Shifts good. One thing I notice is when the rpm's go above 4k the shifter makes a wierd noise. I also noticed it on the freeway. I think it may be the rev. pin tapping the plate when in 5th & 6th gear. Anyone else have this problen. If so how do I fix it?
[same poster, next post] I think the rattle is coming from the shift ****. What would the reason be for this?
[same poster, next post] Maybe not. I can't figure it out and it's kinda driving me crazy. I like the way iot shifts, but for $200, I'm not sure the noise is worth it.
[same poster, different thread] I get a wierd vibrating noise and can't seem to figure it out. Only around 4000k and I also get a wierd noise when shifting. don't notice any vibration though. I thought it was excess grease around the black piece, but I tremoved it all. Then iI noticed some kind of fluid around the ball that goes into the gold color ball. If anyone has any ideas please help me out.
Since there are no further posts from this poster, I don't know if he solved the problem or what. I do remember reading a post about a RE shifter install where the **** buzzed, and the guy was able to tighten the **** down enough to eliminate it. Regardless, there seems to be a hell of alot more positive than negative reviews about this shifter to date.
Because I have installed a B&M shifter on my sedan and my experience differed so markedly from the reviewer, I felt I should respond to a couple of the comments.
- I had no problem positioning the top plate so all gears engaged properly. There was, however, a fair amount of trial and error necessary to acheive this, but I wanted to make certain everything worked perfectly before replacing the console, etc.
- The positioning of the upper shaft to the lower shaft was correct for my shifter. No bushing problems either. In fact, I remain rather impressed with the heft and quality.
- The B&M is definitely notchier but noticibly shorter, and I can now shift in the blink of an eye, MUCH MUCH faster than before! Remember, the notchiness is not a result of the shifter, it is inherent to the tranny. With the change in pivot fulcrum, the shorter throw DOES accentuate the notchiness, and you really do feel each gear "click" as you move in and out. The shorter throw increases shifting force, however, I do not find an inordinate amount of effort necessary to change gears. There is much less play.
- My instructions did not say to remove the camfered shifter **** bushing. But then again, they did not say to reuse it either. It didn't even mention it. But since the length of threads on both shifters looked identical to me, I reused it. The **** snugged down onto the boot cap without a problem. I was careful to twist the boot seams slightly counter-clockwise so when I reached the point of snug, they would straighten without stress.
- The pivot ball housing on my shifter has a rubber O-ring set into a recessed channel around the top. Both are dark so it might be tough to see. This prevents a vibration between the ball housing and the new top plate. Any vibration, IMO, is more likely the result of the new housing rattling in the control socket cup. Obviously, there has to be some play for the ball housing to move up and down in the control socket cup to get to reverse. Since the oem control socket is plastic and slips directly into the cup (it doesn't have an enclosed housing like the B&M), you don't have the possibility of metal to metal vibrations. I would note that there was very little "slop" between these two pieces, certainly tighter than oem, and I used the entire grease tube in the cup (per the instructions) to help minimize this potential vibration. I have no noise unless I hold the shifter tight against a gate.
- Contrary to one post I saw, this shifter is NOT a single piece. It is two piece, with a bonded rubber(?) insert to help absorb tranny vibration. All in all, I would say there may be slightly more vibration felt when keeping your hand lightly on the ****.
Install took 1-1/2 hours by myself in my garage. Easy job, a 4 on a 10 scale of difficulty with absolutely no surprises. I used the instructions from B&M, plus the instructions on Rogue's site and from a site called "350Zchicks" (or something like that) found in the thread mentioned above. I just went slow and careful. The only glaring omission I found in these instructions was a lack of warning regarding the removal of the shifter ****. That bastard is on m'fn tight, and you have to be careful you don't damage the linkage when removing it. Nissan Service Bulletin (NTB02-102) deals with the recommended way to remove the ****.
Respectfully, I must disagree that the B&M short shifter is "a horribly designed POS." I would agree with the majority that this was time and money well spent. In fact, I am firmly in the "best mod under $200" camp. Love it!
2004 | 6MTs | Diamond Graphite/Graphite
Upstate NY
Old May 5, 2004 | 03:32 PM
fluffydot's Avatar
Loren,
Are you going to try the Rogue shifter then?
I would be really good if you can post a review about that too...
man, I would've expected the B&M one to be good since it comes with more stuff. guess I coul be wrong =P
Old May 7, 2004 | 01:44 PM
dholly's Avatar
Well, you know what I find disheartening about this thread? Not that there may be different viewpoints, hell, that happens all the time. But, rather, that so many people who apparently experienced some sort of problem spent the same amount of time to PM one individual instead of posting publicly. The value of every forum is commensurate with the membership's willingness to contribute publicly, particularly when it comes to product warnings. If there is indeed a large contingent of folks having significant problems with this shifter (unrelated to install), I for one would definitely like to hear of them.
Upstate NY
Old May 10, 2004 | 04:29 PM
S2000rs's Avatar
i had a few problems with mine when i first put it in but im sure after fooling around with the triangular plate i was able to make it to my liking. I suggest just moving around the metal plate till you like it.
Old Jul 6, 2004 | 02:16 PM
dholly's Avatar
Sorry for bringing back an old thread but I wanted to append some new comments and pics here as it was the original B&M Shifter thread (other thread HERE).
First, let me say that everything I wrote above was accurate at the time. However, it was shortly thereafter that things began to go bad and I'll do my best to explain...
1.) Although I always had a fair amount of vibration and a bit of audible rattle in the oem shifter during W.O.T. romps, the vibration was noticably increased after the B&M shifter. Initially, it was only a tactile annoyance, rather than an audible one. After a number of weeks though, a very audible rattle appeared to coincide with the vibration. This initially occured only at high rpm's near redline when rowing thru the gears (any), but soon began to exhibit itself at lower rpm's when accelerating as well. So obviously, I decided to call B&M. Some new info that came to light with my subsequent conversations: the pivot ball housing pre-attached on the shifter assembly is NOT made of aluminum as previously noted and stated in most vendor website marketing. According to the design engineer it is a plastic - delrin perhaps, I don't recall exactly anymore, but not metal. Initially, I thought metal-to-metal contact (i.e., the metal pivot ball housing vibrating in the metal transmission cup) was the culprit. Apparently not. Also, the 2-piece shift lever is not entirely machined SS, only the bottom. The top is machined of aluminum. The pivot ball itself is brass. Regardless, the end result was they have received only "isolated" rattling complaints which they a.) contend some rattle is normal for all short shifters; b.) have not seen enough complaints from either 350z or G35 apps to suggest a pattern problem and; c.) have no fix other than to remove it. Pretty much Loren's experience revisited. Sympathetic perhaps, but no help.
2.) Now, had the rattle not been so persistent thru out the entire rpm range I might have been tempted to put up with it for the gloriously short shifts. Unfortunately, after several weeks, I completely lost the 5th gear lock-out without warning. I went to shift into 5th and it just kept right on going all the way right until directly over Reverse. Apparently my initial install positioning of the top plate for proper operation of the lock-out function was adequate, but metal wear of the tang and plate may have caused it to fail. The top plate did not move, and the bolts were tight. I tried to readjust the top plate on a total of three separate occasions, but could never get it to a point where I was comfortable it was making proper contact so...
the shifter has been removed.
Here are some pics showing the wear and positioning of the tang and top plate. Sorry, not hosted so I can’t do multiple pics. One at a time I guess…
Upstate NY
Old Jul 6, 2004 | 02:18 PM
dholly's Avatar
top side wear on top plate
Upstate NY
Old Jul 6, 2004 | 02:19 PM
dholly's Avatar
bottom side wear on top plate
Upstate NY
Old Jul 6, 2004 | 02:20 PM
dholly's Avatar
top plate wear, side view
Upstate NY
Old Jul 6, 2004 | 02:21 PM
dholly's Avatar
wear on shifter
Upstate NY
Old Jul 6, 2004 | 02:22 PM
dholly's Avatar
shifter wear
Upstate NY
Old Jul 6, 2004 | 02:23 PM
dholly's Avatar
lock-out tang and top plate position
Upstate NY
