overdrive
Old Oct 12, 2002 | 03:16 AM
G35c33's Avatar
overdrive
where is it?
Old Oct 12, 2002 | 10:09 AM
Merlin's Avatar
Staff ALUMNI
Re: overdrive
There is no Overdrive like in other cars, where they have a button to engage and disengage. The "G" has 5 gears, the only time that you "drop" down into 4th is when moving from Automatic to Manumatic, it is programmed to always go to 4th, to prevent going to too low a gear and damaging the tranny.
If you want to only shift into 4th and hold it just leave the Manumatic in #4 and that is the highest gear it will shift up to, also any # you leave it in is the highest gear it will shift to, so be careful and remember to shift up. Takes some getting used to w/o a clutch since the "feel" isn't there and the "G" revs to redline pretty fast.
Merlin.
Old Oct 12, 2002 | 01:29 PM
envykillz's Avatar
Re: overdrive
the ecu detects when it needs to downshift on its own.
mIKE
Nov 2, 2017 03:31 PM
Black Betty
Engine - Power Adders
Apr 16, 2013 12:42 PM
xkunalx
Mar 17, 2008 01:39 PM
Gfast
Drivetrain
11
Sep 30, 2007 07:39 PM
