Bunch of noises
Old Aug 14, 2008 | 08:42 AM
Shakuya88's Avatar
Bunch of noises
Alrighty then. The grinding of my back brakes is still there getting fixxed soon, don't fret. But today driving to work I got a new noise. It sounds like it is coming from the transmission and it only happens in 5th and 6th. It almost sounds the same as a belt sliping. It's intermitent sometimes loud sometimes bearly noticable. It's a slipping noise half the time and a faint meshing of gears the other. The times when it's the meshing gears sound I ignore becuase gears are meshing, what I don't ignore is how I never heard it before. Any idea what might have changed?
On my lunch break I'm going to go out and check the fluid level in the transmission and see if I'm low or something and that is causing it.
Any help would be great
Old Aug 14, 2008 | 08:53 AM
Hi-TechG35's Avatar
What exactly does the noise sound like? Do you feel a loss of power in your car when this happens?
Old Aug 14, 2008 | 11:11 AM
Shakuya88's Avatar
It sounds like a fast pased high pitch squeaking. Have you ever had a belt slip? It sounds a lot like that sometimes and other's it's just the squeaking. I really wish I knew how to describe it better. Lunch in an hour so I'll be checking fluid level then. Hopfully not that. Could low fluid cause a weird noise anything like this?
Old Aug 14, 2008 | 08:56 PM
Shakuya88's Avatar
Alright, so things got worse on way home. Now there is a bad shaking of the shifter in all gears Going in for service tomorrow
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
