Transmission oil
Transmission oil
Guys i have a 03 coupe and id like to know my car has 55k miles on it, if i want to change my transmission oil (Matic J), would it give me any trouble to my transmission after. I mean is it too late to change it?
really no reson to change it unless you beat the **** out of it every day.
i suggest you check the level. if the level is okay, the the fluid looks cherry red, your good to go.
A drain and fill is recommended every year or a complete flush every 2 years.
Changing the fluid at regular intervals is the key to a long lasting transmission. That and keeping the heat under control (if the car is modified).
You should've had a flush at 30k miles. I would take it to the dealer and tell them you want them to flush the tranny and in the process make sure the tranny cooler is flushed independently to get rid of debris in it before hooking it back up. That's the only thing that can cause problems from the flush.
Originally Posted by Gdupg
So now that my car is at 55k milesi should drain and fill it back and change the tranny cooler also and im set?
i think my first tranny change was like @ 50k too
Originally Posted by joedaddy1
just drain and fill.. i dont think there's a need for the tranny cooler..
seagrasser
May 3, 2022 09:43 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
