Drivetrain issue?
Old Dec 10, 2008 | 07:21 PM
Mr. G35's Avatar
Drivetrain issue?
I will do my best to describe the problem that I encountered today, and hopefully someone can help me out.
I was heading to work this morning and everything was fine. When I pulled into the parking lot and applied the brake, something fishy was going on. It felt like a spring down around my brake pedal was loose. I thought that maybe I should look around to see if there was a loose spring. On my way home, it did it again. It only happens when I am slowing to a complete stop and when I have my brake applied. Inside the car, I can feel a vibration and hear a "doing....doing....doing" almost like a spring is loose. I haven't been able to figure out the problem, and thought that maybe it could be a drivetrain issue. If not, maybe a clutch issue? It's funny this doesn't happen when I have my clutch in. Could it maybe be an e-brake cable? Anyone ever encounter this type of issue? Thanks
Adam
Old Dec 10, 2008 | 08:12 PM
Canadian's Avatar
Canada, eh?
I honestly don't understand what you're problem is. Are you saying you get a soft/weak pedal? What spring are you talking about? There are no springs...
Are you getting vibration in the brake pedal? A grinding sound? You need to tell us how the pedal feels.
Old Dec 10, 2008 | 10:52 PM
Mr. G35's Avatar
Hey man, thanks for responding to my post. I am trying to explain the problem as best I can. When coming to a stop light....I put my car in neutral. As I approach the stop light, I will apply my brake (and only my brake, not any other pedal) and when the speed of the car decreases to about 5-10mph range, I feel a vibration, and there is a sound of something similar to a spring (the sound of a spring as it expands and then contracts) and feels like it is interfering with my brake pedal. The sound is almost in tune with my driveshaft, it is not a constant sound. It is not a grinding sound, my brakes are not squeaking, and the brake pedal does not feel any different as I push in. I just had my car out for about 20 mins and did not have this problem. I am troubleshooting the problem now, so it doesn't lead to bigger issues down the road.
Old Dec 10, 2008 | 11:00 PM
Texasscout's Avatar
How many miles, sounds like you "wear indicators on the pads are sounding off.
Old Dec 11, 2008 | 01:13 PM
Mr. G35's Avatar
Car has just over 44k miles. The car runs fine mechanically.
Old Dec 11, 2008 | 03:54 PM
Texasscout's Avatar
Yeah, the brakes on the 04's were a little softer and made more dust than the 05's and later. So I would have the pads checked for wear.
Old Dec 11, 2008 | 04:46 PM
Mr. G35's Avatar
Thanks for the advice...i'm going to take a look at that. Yea the brake dust is pretty crazy. My wheels are dirty within two days of washing my car.
G35Rican
Jul 31, 2024 01:37 AM
cmesidewayz
Sep 29, 2015 09:28 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
