Transmission fluid level
Old Jun 6, 2004 | 11:24 AM
theskipps's Avatar
Does anyone know where the fluid level on the stick should be?I noticed that there are two notches on the stick .Are these where the level should be.Which notch should it be on and is it better to check hot or cold.
Thanks
Old Jun 6, 2004 | 03:53 PM
DaveO's Avatar
Re: Transmission fluid level
theskipps,
I check mine hot with the engine running in "P". The level should be in the cross-hatched pattern (highlighted in red).
If you check it cold, be sure to cycle between "R" and "D" a couple of times with the engine running first. Then, with the AT in "P", the level should be in between the two notches where the word "HOT" is located.
DaveO
2003 G35 AT Sedan / DP / Willow / Premium / Sport
350Z Air Duct, Eng Cvr & T-Stat / Stillen CAI / Crawford Plenum
GG 10-Wire Kit / TS ECM / E-Fans
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Jun 6, 2004 | 04:16 PM
Gordgee's Avatar
Administrator
Why would they put "HOT" and the notches below the cross hatch pattern? There's probably a reason, but I can't think of one right now.[img]/w3timages/icons/blush.gif[/img]
<font color=blue>[i]GroundingGear™ Equipped </font color=blue>
Old Jun 6, 2004 | 04:40 PM
dave's Avatar
So if the transmission is COLD, you take a reading where it says HOT?
Ok, these Infiniti people have to stop messing with my head...
2004.5 DG/G 5AT Coupe with all options
Sidemarker turnsignal mod
GroundingGear™
2003 Yamaha YZF600R
Old Jun 6, 2004 | 09:17 PM
bkchang79's Avatar
I don't have a A/T G35, but I know a couple AT cars I've driven have a HOT and COLD reading on the dip stick. You use the COLD reading when the tranny is cold (driven a couple miles, mild traffic, etc.). You use the HOT reading when the tranny is warm or hot (lots of stop and go, 10 miles or more, etc.). The hot and cold reading could be on either side of the dip stick, but sometimes they point out the HOT reading is higher then the COLD reading.
2003 G35 Coupe 6mt Diamond Graphite
AIM= bkchang79
http://www.sounddomain.com/id/bkchang79
Old Jun 7, 2004 | 09:30 PM
theskipps's Avatar
Thanks for the information,i really appreciate the picture.
Old Jun 7, 2004 | 10:55 PM
DaveO's Avatar
Gord,
The newer service manuals tell all.
Hot (65C or 149F) is read on the side that says HOT. The level shoild be in the cross-hatched area.
Cold (30-50C or 86 to 122F) is read from the backside of the "oil level gauge" opposite the word HOT. Normal level is between the two notches.
We're not alone in our confusion. I believe the newer (non-gray market) oil level gauges have the word HOT above the cross-hatched area.
DaveO
Old Jun 7, 2004 | 11:20 PM
Gordgee's Avatar
Administrator
Thanks. That sort of makes sense, if they have COLD stamped on the other side with the cross hatched area between the notches. If not, then....well, we didn't design these things, did we?[img]/w3timages/icons/tongue.gif[/img]
g.spot
May 9, 2016 10:54 PM
f22raptor
Mar 18, 2016 08:50 AM
mbe32
Nov 13, 2015 11:09 PM
AL8782
Oct 3, 2015 10:26 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
