Clutch problems
Old Dec 25, 2008 | 04:38 PM
1sweetg35's Avatar
Clutch problems
First off just want to say merry christmas to everybody. But I wondering whats going on with either my clutch or clutch pedal. When I let the clutch out, the pedal doesn't come all the way back up. It stops about a inch or 2 short and you have to tap it back up with your shoe. And the clutch pedal is squeeking sometimes. It almost seems like the clutch pedal assembly needs to be lubed or something. Anybody have any idea whats going on?
Old Dec 26, 2008 | 07:58 AM
1sweetg35's Avatar
Well I ended up finding some synthetic grease in my garage and I put some on all the moving parts to the clutch pedal and it actually fixed my problem. Clutch pedal comes all the way up again and no squeeking. Anybody else had this problem before?
Old Dec 26, 2008 | 11:22 AM
CreativeDesignZ's Avatar
yea i had that problem as well. actually the clutch went out about a month after that occured...
Old Dec 26, 2008 | 11:26 AM
Texasscout's Avatar
I took mine to the dealer with the same problem, they flushed the system and it cured the problem so far. With 70K+ in the car, I think a new clutch is in the stars soon anyway. Let's hope it lasts through the Raging Bull in January.
Old Dec 26, 2008 | 12:12 PM
1sweetg35's Avatar
Yeah it might be a sign the clutch is almost done for me. The clutch lets out real high and when you let out it chatters a little bit. So here in the next few weeks I will go ahead and put in a lightweight clutch and flywheel in it.
Old Dec 26, 2008 | 01:12 PM
LittleItalyG's Avatar
I wouldn't rush out and buy a new clutch just yet. sounds like your clutch fluid has gotten too hot and needs to be flushed. easy DIY. very common with our Gs. make sure to use synthetic high temp fluid and i bet you will be good to go
Old Dec 26, 2008 | 01:40 PM
1SlowSedan's Avatar
Do a search, there are tons of threads about this. Get your clutch slave cylinder replaced.
Old Dec 26, 2008 | 02:43 PM
Darkstar752's Avatar
Actually vhtran is on 130k on his original clutch, so maybe it's not so close
Old Dec 26, 2008 | 03:19 PM
1SlowSedan's Avatar
Average clutch life for our G's is 50 to 60k. vhtran must be doing 90% highway miles.
Old Dec 26, 2008 | 06:24 PM
1sweetg35's Avatar
Thanks for the advice guys. I will try changing out the clutch fluid first and then if it happens again i'll take it to the shop and see if its the clutch slave cylinder before replacing the clutch. Thanks again!
11bEMT
May 27, 2022 03:13 PM
zcherub
Aug 30, 2015 05:04 PM
NemesisGee
Aug 11, 2015 07:10 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
