can you change the diff fluid with ramps on the rear
Old Jan 3, 2009 | 09:54 AM
dofu's Avatar
20 Year Member
Originally Posted by SwanyJr
If you jack the car back up to finish the job, your fluid level reading will be off due to the angle of the car...
That's right, I'm thinking about changing the oil at home... then just drop the car back down and pump the fluid in... it might sound like a lot of work, but it's still a lot less work than putting stands on all 4 corners.
Old Jan 3, 2009 | 04:44 PM
SwanyJr's Avatar
put jacks on the front and jack up the back...just takes two jacks that way
Old Jan 4, 2009 | 11:00 PM
wiz2's Avatar
Originally Posted by mikeee2
Just curious what kind of fluid extractor you have and what other duties do you made use of it?
Thanks...
The model I have is shorter and metal I cant find a pic online,but same principal as this one.
This thing rules when its time to drain slushbox tranny fluid in the wifes Honda and friends vehicles. I usaully pop the drain plug as well if the plug is magnetic to clean off any fine shavings. This depend on the vehicle. I've used it to suck out other fluids like a fuel from my weedeater when doing a minor rebuild.
b2autodesigns
Accessories-Vendor
70
Feb 25, 2017 01:12 PM
NemesisGee
Aug 11, 2015 07:10 PM
edwinisdumb15
SOCAL Meetings & Events
Aug 3, 2015 10:42 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
