Burnt Clutch
Old Feb 9, 2009 | 01:39 AM
rookie's Avatar
Don't get a twin carbon, that's a bit overkill. Get a single for normal use. OS Giken single is 1100ish.
Old Feb 9, 2009 | 01:42 AM
Beebo's Avatar
i may supercharge or build the engine down the road since i have some money coming in, still get single?
Old Feb 9, 2009 | 01:50 AM
rookie's Avatar
SCing doesn't generally add that much more tq which is what most clutches are rated for. JWT organics usually hold up to stock block SCing. I guess it's up to you how much clutch you need.
Old Feb 9, 2009 | 09:19 AM
SPEC-01's Avatar
I am sure that you know there is a pretty major difference between "can" and "should". You certainly "can" opt for a clutch that has a higher capacity than you need and you "can" spend tons of money doing so. Based on your planned output a single disc would be a fine option. I suggest a hybrid or full-faced disc (which will provide better drivability and increased torque capacity). For instance a Stage 2+ (this unit utilizes a segmented Kevlar face on one side of the disc and a carbon-semi-metallic face on the other side) or a stage 3+ (which uses a full-faced CSM face on both sides) would easily provide you with plenty of capacity for boost while having a much lower cost than an un-needed multi-disc.
If you go the route of a single disc then you can choose to use either a steel flywheel (which will better dampen and thus lessen the amount of gear-noise transmitted by the transmission) or a lighter aluminum flywheel which will save wait and greatly improve both the increase and decrease of RPM while allowing the car to put more power to the wheels.
Of course, I recently installed our SN35SST which is [art of our Super-Twin line of offerings and it too is rated to 800 lb-ft. at the crank. If you choose to go this route make sure you get a kit that is fully rebuildable. I suggest this because there is nothing like dropping a few thousand dollars on a Carbon based clutch kit only to have it wear out and be faced with buying another one. Our Super-Twin's are completly rebuildable and upgradable. I have provided a link to the page below. Let me know if you have any further questions. Thanks...www.specclutch.com.
Old Feb 9, 2009 | 09:26 AM
lekker_droom's Avatar
Rookie is absolutely correct here. This is why I suggested you look at single disc as well. And OS Giken is awesome too, equally as good as Carbonetic. Either brand will be perfect.
I only went with twin disc for future build up. Last clutch I'll ever need (fingers crossed).
Old Feb 9, 2009 | 08:46 PM
Beebo's Avatar
i think i just may stay OEM because my auto shop teacher said he can get me a good deal, i have a few days to think about it lol
btw the car is undriveable lol wont go into gear at all lol
Old Feb 9, 2009 | 08:53 PM
INF G'd Up's Avatar
did you check with some of the vendors in the marketplace
Old Feb 9, 2009 | 08:54 PM
Beebo's Avatar
i was just doing that lol... found a good deal on OEM clutch
Old Feb 9, 2009 | 08:57 PM
INF G'd Up's Avatar
lol very nice
Old Feb 16, 2009 | 07:45 PM
Beebo's Avatar
Update
My G is at a friends shop (they do good quality work and have been doing it for 30 years, and i know he will be honist with me and wont screw me) it will be $1300 for the “standard” clutch and $1500 for the "High Performance clutch"
Q: what the hell is the difference between the "standard" and "high performance"? Is it worth a $200 difference in price?
Q: will I need a Flywheel?
If I get the clutch + flywheel it will be $2400
Thanks,
-Wes
Old Feb 16, 2009 | 07:48 PM
rookie's Avatar
Jesus, how much is install? Technosquare does it 400 or 450 I think.
Old Feb 16, 2009 | 07:51 PM
Beebo's Avatar
those prices are with install
that clutch+flywheel install price of 2400 was just a guess, im really not sure
Old Feb 16, 2009 | 11:44 PM
Beebo's Avatar
Bump
Update
Thanks,
-Wes
P.S. I need to know by tomorrow morning, anyone?
Old Feb 17, 2009 | 08:52 AM
Beebo's Avatar
anyone?
Old Feb 17, 2009 | 09:23 AM
  #30
Standard and high performance what? Is he talkin about the OEM setup? That there is supposedly two option for an OEM setup?
And FYI, I paid 550 for clutch and flywheel install.
