UR Underdrive Pulley Belts
Apr 1, 2009 | 04:17 PM
does anyone know the size belts needed for the underdrive pulley kit from UR? thanks.
Reply 0
Apr 3, 2009 | 03:27 PM
anybody??
currently have Gates and they are cracking after three years. also have to run belt tensioner all the way out on these. would like to try another brand, but need the correct sizes to order. would appreciate some help since I could not find via search.
thanks.
Reply 0
Apr 7, 2009 | 04:02 PM
no one else has the UR Pulley set?
Reply 0
Apr 7, 2009 | 11:52 PM
you can purchase the belts from intense power, i dont know the sizes but am sure if you were to contact Unorthodox they could help you out
Reply 0
Apr 8, 2009 | 07:39 AM
^ yeah the belts I was sent last time did not fit. had to have mechanic find something on short notice and now I am running with the belt tensioner all the way out because these dont really fit that well and kept squealing.
I just though someone on here with this setup could recommend the proper size and a good replacement brand.
Reply 0
Apr 9, 2009 | 10:55 AM
just in case anyone needs this info, you need an 1150mm for the main drive belt and 910mm for the accessory belt. hopefully this will help someone else in the future.
Reply 0
