03AT Changing Final Drive
Old Aug 18, 2009 | 07:41 AM
bigdano's Avatar
Hi I would like to change my final drive to that of a 07-08 g35 sedan (3.7)
Anyway I have the vLSD. I am looking for a pumpkin and everything from salvage yards across the United States. Do I want the locking or non locking carrier?
Dan
Old Aug 19, 2009 | 12:15 AM
Tollboothwilley's Avatar
which is used with the RAS? You don't want that one...
Old Aug 19, 2009 | 06:36 AM
bigdano's Avatar
the RAS? whats that?
Old Aug 20, 2009 | 02:16 AM
bigdano's Avatar
Bump
Old Aug 20, 2009 | 02:20 AM
bigdano's Avatar
Whats the difference between locking and non locking
front (3.692 ratio)
rear, AWD (3.692 ratio)
rear, RWD, 4 Dr (Sdn, 3.692 ratio), locking, MT
rear, RWD, 4 Dr (Sdn, 3.692 ratio), locking, AT
rear, RWD, 4 Dr (Sdn, 3.692 ratio), non-locking
rear, RWD, 2 Dr (Cpe, 3.538 ratio), locking
rear, RWD, 2 Dr (Cpe, 3.538 ratio), non-locking
Old Aug 20, 2009 | 03:03 AM
ttrank's Avatar
Grocery getter
oem locking is a VLSD.
If you just want to change the final drive it does not matter but if you are doing a LSD at the same time you will want to make sure the new one is setup to work with the type you buy. Search is your friend here, there is tons of info.
Old Aug 20, 2009 | 03:18 AM
drifts500's Avatar
RAS= Rear Active Steering (Rear wheels move a little) Go to youtube and do "RAS G35"
Old Aug 22, 2009 | 11:50 PM
bigdano's Avatar
OK but RAS doesn't pertain to me... I just need to know if the stock 2007 and 2008 final drive will work in my sedan... Should I get the locking then?
Old Aug 23, 2009 | 08:34 PM
bigdano's Avatar
bump
Old Sep 1, 2009 | 01:00 PM
The gears should work, I'm not sure if the full pumpkin is interchangeable though
whattf
Drivetrain
Jul 20, 2015 11:19 AM
Ninjay16
Jul 20, 2015 01:21 AM
