Auto Trans keeps G35X 04 to start
Old Dec 11, 2009 | 04:02 PM
12bbb's Avatar
I can't start the engine.
When I turn the ignition to on, transmission lettres don't appear on th instrument cluster. I move the shifter back and forth then try again, and still no start.
I also tried in neutral, same result.
My mechanic tell's me it's maybe a major tranny problem.
I got 179000 Km
Old Dec 11, 2009 | 06:07 PM
Tollboothwilley's Avatar
Thats a bad sign.
If you aren't getting the "AT Check" at startup I would be worried.
Old Dec 12, 2009 | 09:17 AM
12bbb's Avatar
Yes I am getting the
AT Check light
Old Dec 12, 2009 | 02:56 PM
does it go off?
Old Dec 12, 2009 | 03:00 PM
I guess what you're trying to say is that the "gear indicator" light on the dash is not displaying your gear, is that correct? And your car isn't starting because of this?
So you are stuck in a "no gear" right now. Does this ONLY happen for (P)Park or does it happen for your other gears as well?
Old Dec 12, 2009 | 08:31 PM
12bbb's Avatar
My mechanic found the probleme by pur luck.
Blown fuse.
And yes the gear indicator didn't display any of the gears.
Now the probleme is, why did the fuse blow?
Old Dec 14, 2009 | 05:06 PM
did you spill a drink into your center console? water get into the car somehow? Who knows. If it keeps popping the fuse then you need to look for a serious issue. If not, carry on driving as normal.
Mry
Mar 3, 2023 01:03 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
joedaddy1
Jul 28, 2015 02:58 PM
newg37
Jul 26, 2015 09:32 AM
realtalk21
Jul 20, 2015 09:07 AM
