Open rear end to VLSD swap ?
Old Sep 9, 2004 | 09:34 PM
booger's Avatar
Has any one changed the open rear end to a VLSD ? If so what is needed ? Parts....Cost.....Or has any one put MT6 ring and pinion in an open rear end ?
Couldnt afford it when young...gonna play when Im old
Old Sep 10, 2004 | 12:14 PM
g35_6gear's Avatar
Re: Open rear end to VLSD swap ?
You can do a search for www.car-part.com under carrier.
You can get an entire rear diff from a 350Z,g35 for $300-400 complete. That's what I did and it worked great. No messing around.
2003 6mt sedan, Labree test pipes, Greddy evo-2 catback, Coupe LSD, 350Z ecu swap,
Brembo brakes, Skyline badging/sills, 18" coupe wheels, DC headers, grounding kit, custom intake manifold, Injen CAI
Old Sep 11, 2004 | 01:24 PM
Buddha's Avatar
swapping a VLSD is not as good as getting a clutch type differential such as the nismo or kaaz. For alittle more money, you're getting a betty LSD.
04 G35C 6mt/aero kit/nav/premium
Old Sep 11, 2004 | 05:39 PM
Q45tech's Avatar
True except the [used junkyard takeout] viscous is maintenance free [other than changing the diff fluid every 2 years] for at least 100,000 miles.........whereas internal work and rework and rework maybe required with other types to keep them optimized.
Old Sep 12, 2004 | 09:40 AM
Tfasano's Avatar
QTech, is this true for the NISMO LSD as well?
www.nypokertour.com
Old Sep 12, 2004 | 10:31 AM
Q45tech's Avatar
Mechanical gear and clutch type have wear but either type seem to last as a function of power applied and 260 lb/ft [multiplied by gears] is not a lot of torque as these usually see super/turbocharged service.
Not to say that you can't over heat a viscous and cause them to fail.............the slip ratio increase with stress and temperature also.
The real factor is tire friction [like with drag slicks]. Why they make diff coolers with recuirculating fluid pumps for extreme duty.
I have much more experience with viscous than the other types so I may be biased.
Muski_G
Dec 1, 2023 11:11 AM
rezendvous420
May 31, 2020 01:26 PM
atk08
Jul 30, 2015 03:12 PM
whattf
Drivetrain
Jul 20, 2015 11:19 AM
