Exedy OEM clutch and ACT flywheel
Old Apr 12, 2010 | 10:53 PM
atcskillz's Avatar
Respect others!
Just got this combo installed today. Clutch pedal feels way softer and doesn't feel like its fully engaging when i shift to higher gears. Sort of like clutch is still depressed for a little while as the car accelerates. Is this normal for a new clutch for a few miles or so? Break in period maybe?
Old Apr 21, 2010 | 11:33 AM
arsine's Avatar
the pedal shouldnt feel any softer. have you checked the fluid level?
Old Apr 21, 2010 | 04:00 PM
abcdo4dkIdjkm's Avatar
how do u like the act flywheel. Does the car feel quicker? How is the noise? +1 on check fluid and clutch line.
Old Apr 21, 2010 | 05:00 PM
arsine's Avatar
at highway speeds it definitely has a lot more pull. there is some clatter at idle but it doesnt bother me. i also had a braided steel clutch line put in too. if youre putting in a clutch kit with more clamping power than stock, a chrom moly pivot ***** a good idea. the oem can break under the added stress
11bEMT
May 27, 2022 03:13 PM
NemesisGee
Aug 11, 2015 07:10 PM
TurboEE
Jul 31, 2015 10:41 AM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
