Exedy stage 1 with stock flywheel on 2005 coupe 6mt
Old Sep 15, 2010 | 02:29 PM
antodiaz's Avatar
Well I just had my Exedy stage 1 clutch kit installed on my 2005 g35 6mt with a resurfaced stock flywheel and everything is perfect no chattering clutch pedal is a little stiffer from the new pressure plate but no big deal. The clutch engagement is a little lower on the pedal but it feels like a new car shifting thru the gears. I can't wait for the break-in period to be over.
Old Sep 15, 2010 | 02:35 PM
abcdo4dkIdjkm's Avatar
who resurfaced the stock flywheel? I was under the impression that shops wouldn't do that.
Old Sep 15, 2010 | 03:01 PM
Princedrama's Avatar
why did you replace the clutch? were you having slipping problem?
Old Sep 15, 2010 | 06:03 PM
antodiaz's Avatar
the mechanic did, the thing is that the flywheel was actually in great condition with 60k miles on it so it was lightly resurfaced. it wasn't like a machine shop resurfacing he did it by hand and Im really impressed with the results.
Old Sep 15, 2010 | 06:08 PM
antodiaz's Avatar
I replaced it because it was slipping like crazy in any gear. I was really impressed when I saw that the flywheel was in great condition. On the other side the clutch disc was gone.
Old Oct 6, 2010 | 03:54 PM
adi1ias's Avatar
My situation is I have a 2005 G35 Sedan 6MT with 76K miles and my clutch disc needs replacement. I am doing research and am considering purchasing an Exedy or other reputable brand clutch over OEM. You all are a huge help in my process! We will see how it goes.
A few questions for antodiaz:
1. How much did you pay for the Exedy Stage 1 clutch?
2. How much did you pay for clutch installation?
3. How much did you pay to resurface the flywheel?
4. How long is the break in period?
5. Where did you get the exedy clutch?
6. Did you do any pedal adjustments?
6. Although its still early, do you have any issues now?
Mind you I am a newb. I read from another forum on break in period.
Break In Period for Exedy Clutch
150-200 miles, but all depends on driving style
http://www.exedy.co.uk/index.php?main_page=faq_page
Thanks so much for your help!
Old Oct 6, 2010 | 04:05 PM
antodiaz's Avatar
[QUOTE=adi1ias;5398086]My situation is I have a 2005 G35 Sedan 6MT with 76K miles and my clutch disc needs replacement. I am doing research and am considering purchasing an Exedy or other reputable brand clutch over OEM. You all are a huge help in my process! We will see how it goes.
Thanks so much for your help![/QU
1. I paid $385 for the exedy stage 1 clutch kit on ebay
2. The mechanic charged me $200 for the installation took him about 6 hours and he did the resurfacing since the flywheel was in excellent condition
3.^^^^^
4. according to the instructions break-in period should be 750 miles
5. ebay. one of the sellers has a buy it now or best offer so I offer him $385 and he accepted the offer
6. no pedal adjustments it was harder than the stock clutch due to the higher clamping force on the pressure plate but it has gotten softer and it will engage a little bit lower.
7. 500 miles into it no issues at all.
hope this helps by the way Im located in Clearwater/st. pete, FL in case youre from FL and would like to go to the same mechanic he is pretty good and well known locally
Old Oct 6, 2010 | 04:11 PM
adi1ias's Avatar
Huge Help! Appreciate it.
Im actually in Boston, Mass but with the rain wish I was in Flrorida.
Thanks again antodiaz
Old Oct 6, 2010 | 04:17 PM
antodiaz's Avatar
By the way this is the seller just offer him $385 he'll take it.
//http://cgi.ebay.com/ebaymotors/EXEDY-RACING-STAGE-1-CLUTCH-03-07-G35-03-06-350Z-VQ35DE-/130409104979?pt=Motors_Car_Truck_Parts_Accessories &hash=item1e5cfd0653
Old Mar 26, 2011 | 02:50 PM
kosh's Avatar
$200 sounds like a great deal...
Can you provide mechanic contact info?
Old Mar 17, 2012 | 11:35 AM
chalyse's Avatar
hey antodiaz,
i'm thinking about doing this exact setup. stage one clutch and a new dual mass flywheel.how are you enjoying the ride so far. would you change anything and or you happy still with the set up...please let me know asap...I am on ebay right now...lol
Old Mar 17, 2012 | 12:05 PM
antodiaz's Avatar
Don't do it!!!! Long story short after about 4 months the throwout bearing started making noises couple weeks later clutch is gone!! The bearing literally fused to the pressure plate and burned the heck out of the flywheel anyways I had to replace the clutch, pressure plate and flywheel ($750) not including labor. After that I went with the oem clutch that is actually made by Exedy and an ACT flywheel. Problem solved. Also the pressure plate on the stage 1 has hard as F$&k.
Old Mar 17, 2012 | 12:21 PM
chalyse's Avatar
dude,
thanks alot...the set up seems so do able...what went wrong...
Old Mar 17, 2012 | 12:25 PM
chalyse's Avatar
Im thinking the flywheel was the culprit, it was worn...yet again...the clutch might have being too powerful for the dual mass flywheel...what does anyone else have to say bout this...
Old Mar 17, 2012 | 03:23 PM
antodiaz's Avatar
IMO the problem is the pressure plate.
