Clutch engagement too low!
Old Sep 19, 2010 | 01:00 AM
F1SportsFan's Avatar
Hey everyone, I just got my clutch/flywheel replaced with Clutchmasters Stage 1 and NISMO flywheel, as well as the pivot ball and shift fork. Now the clutch seems to fully engage about 1/4 inch off the floor. It's pretty hard to drive smoothly, and I'm concerned its not disengaging fully with the clutch depressed.
I found lots of threads about lowering the shift point, but not much about raising it. Should I do the lowering process but thread the shaft the other way to raise it? Or am I better off just taking it back to the people who did the work? With all the $$$ in parts and labor, I want to make sure it doesn't get screwed up.
I've been "lurking" for a while but this is my 1st post, so thanks for your thoughts.
Old Sep 20, 2010 | 09:15 AM
antodiaz's Avatar
thoughts.
Well I just got my clutch replaced with a exedy stage 1 and the same thing happened to me but after a week it went back to the normal engagement point and a lot smoother too.
Old Sep 20, 2010 | 03:16 PM
HotRodG35's Avatar
You can try adjusting clutch cable by loosening locknut and turning clutch cable counter clockwise 1/2 turn at a time until engagement is satisfified.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
mattdg35
Sep 14, 2015 11:28 AM
jbmw002
Sep 10, 2015 12:54 AM
Jnm07
Sep 5, 2015 01:16 AM
