Diff Oil Recommendations?
Old Oct 31, 2004 | 05:00 PM
roneski's Avatar
Devil's Advocate
Re: Diff Oil Recommendations?
I read the same thing. Castrol uses a modified dino base that they call synthetic. Mobil uses a truer engineered PAO synthetic, as does Amsoil and some others.
The funny part is that the Castrol costs half as much to make, but they didn't feel like passing that savings onto the consumer. Still costs as much as the Mobil.
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves."
-- Abraham Lincoln
Old Nov 14, 2004 | 03:31 PM
roneski's Avatar
Devil's Advocate
Got around to changing mine the other day at about 8500 miles. There was a significant amount of metal on the magnet. I replaced the fluid with Amsoil Severe Gear 75w-90. Runs great. I plan on changing it in about another 10k miles or so.
-- Abraham Lincoln
Old Nov 14, 2004 | 10:59 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
I just recently changed mine...one thing I was told was, if you have dif troubles and the dealer sees anything other than Nissan oil, they'll blame that and not cover it...good luck...whilw you're there, change your tranny fluid too....I did
Wanna see mine?
Old Nov 15, 2004 | 08:19 AM
roneski's Avatar
Devil's Advocate
I had the dealer do my auto tranny fluid. Shifting seems to be a little smoother.
-- Abraham Lincoln
Old Dec 2, 2004 | 03:04 PM
accordfreak's Avatar
i thought the rear diff only uses 80w 90? not 75w 90?? will it matter?
Old Dec 4, 2004 | 11:53 AM
snapon's Avatar
Castrol SAF-xj 75W140 isn´t too bad, also Shell 75W140 for LSD used for the M5´s etc with LSD´s.
In general the diff. on the g35 is a rather weak spot and for sport use the use of a cooler with a high capacity pump should be considered.After 10000miles of Nuerburgring racing our g35 diff is still in pristine condition.
Old Dec 6, 2004 | 02:00 AM
kwakman's Avatar
How much did u guys pay to have the rear differential fluid replaced? I'm thinking about getting it done asap but being a college student, money is tight.
Old Dec 6, 2004 | 05:07 PM
ensor's Avatar
huh
i already had an oil change scheduled for wednesay (3750 miles). and called up to add a rear differential fluid change as well, he's unsure of the price as they've never done one before.........
Old Dec 9, 2004 | 09:57 AM
ensor's Avatar
labor: 37.50
parts: 16.46
shop supplies: 4.50
total: 58.46
Old Dec 10, 2004 | 12:25 PM
mrmcderm's Avatar
Is that even legal? I think there are plenty of examples out there where the dealership/factory had to cover a repair because they couldn't prove that the upgraded fluid did the damage.
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
celwin
V36 Engine, Exhaust, Drivetrain & FI
11
Sep 28, 2015 03:52 AM
johnadlertech
Engine - Complete Motors
Sep 6, 2015 12:45 PM
UT G35
Sep 3, 2015 03:58 PM
