5th gear grinding once after start up?
I got a 05, 6MT and i jus recently did a clutch swap about 7-8 months ago to JWT clutch, light flywheel the whole 9. Within the last month or so, I've just noticed my 5th gear making a grinding noise once i put it in 5th ONLY ONCE and ONLY the first time i put it there. After it makes that noise that one time, it will will be fine and not make it again usually that entire day. I can shift to 5th 1,000 times and it will never do it again. Not untill the next day after everything seems to have cooled off and is cold again...its does it once, and then its fine again. I can feel it grind in the shifter as well. I dont wanna be messing anything up. Does anyone know wut this may be?
I'm having the exact same issue. Grind's into 5th once after I start the car, and then that's it for the whole day. I'm at 85k miles, and don't believe my transmission fluid has ever been changed.
Frostbite91
Aug 20, 2015 07:20 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
