AWD Question
Old Dec 29, 2010 | 01:24 PM
BuzzLightYear's Avatar
AWD Question
Anyone know what the AWD service performed by the dealer consists of? The dealer recomended that I have it done. I see the diy for the rear diff and it looks pretty simple and was thinking of just doing it myself, but was just curious to what the dealer includes in there service. I'm guessing rear diff, transfer case, and front diff if there is one? Anyone have a diy for the transfer case? One other question, when doing the awd service is it necessary to do a transmission flush at the same time? Thanks in advance!
Old Dec 29, 2010 | 05:54 PM
brandon1978's Avatar
The info you need is in the factory service manual, which you can find here: https://g35driver.com/forums/faq-diy...e-manuals.html
There is not a specific checklist for AWD service; you just have to look at the maintenance items that apply to the AWD system. Basically inspect front & rear diffs, front & rear prop shafts, and transfer case for damage and leaks. Then drain and fill diffs and transfer case. No need to do the transmission at the same time. DIY doesn't get much easier than drain and fill, so yes you should do it yourself.
Old Dec 29, 2010 | 09:20 PM
Thanks alot for the info & link! Def going to try and do this myself once the weather gets a lil warmer.
Alex Koss
Oct 29, 2021 12:53 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
TL2G35x
Aug 12, 2015 10:30 AM
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
