Transmission problem??
Old Jan 11, 2011 | 11:09 AM
Eticketride's Avatar
I have an original 2003 G35 Sedan, 5AT with about 100,000 miles. While going down the freeway this morning, something weird happened. I was going 70mph and I wanted to pass another car. I gently accelerated and my speed did not increase. I gave it a little more gas and nothing happened. I looked at the tach and it increased to 4000-5000. My speed dropped to about 65mph but it didn't fall rapidly. So my tach was responding, I could hear the engine roar, but my speed was not increasing...After about 20 seconds or so, my car was normal again. I didn't feel it kick into gear, it just started responding again. Anyone have any ideas on what could be wrong??
Old Jan 12, 2011 | 12:09 AM
NFSP G35's Avatar
? = 2B || !2B
Do you have a CAI and was it raining?
Old Jan 12, 2011 | 11:01 AM
Not sure what CAI means...
It was not raining or even wet.
Old Jan 12, 2011 | 11:03 AM
On my way home last night it did it again. It does not do it from a dead stop or going at low speeds. But when I am at a constant speed of 40mph or greater it happens. I step on the accelerator, the engine revs, and my speed stays about the same. If I keep accelerating, slowly the gears will engage and the car will start to accelerate. kinda like a clutch slipping on a manual transmission...
Old Jan 12, 2011 | 11:07 AM
acr's Avatar
acr
could this be a torque converter problem? Do our cars have torque converters?
Old Jan 12, 2011 | 11:36 AM
NFSP G35's Avatar
? = 2B || !2B
sorry, CAI = Cold Air Intake.
My car did this before, but it's been a long time.
When it did it, it also threw a light about running lean (which I determined was due to my CAI filter getting wet in the rain.
IDK if the two problems were related or not
Old Jan 12, 2011 | 12:27 PM
MM_G3520's Avatar
Yes, the autos have tq converters.
OP, I'll have a PM for you today or tomorrow.
Old Jan 13, 2011 | 05:38 PM
OK, my neighbor was able to get to the transmission fluid and says that the fluid smells burnt...I'm not sure where I want to go from here. Should I spend the money to diagnose the problem further??
Old Jan 13, 2011 | 05:40 PM
NFSP G35's Avatar
? = 2B || !2B
^Why don't you just change the fluid and filter and see if the problem goes away.
Old Jan 13, 2011 | 08:28 PM
pickrice's Avatar
have you done a transmission flush? if not, this could very well save your transmission if that is the issue in question
Old Jan 13, 2011 | 08:49 PM
Blue Dream's Avatar
I drove ttrank's car solo
No "filter" to speak of n00b.
OP definitely change the fluid or have it done. Stick to Nissan S-Matic for best results IMO.
Old Jan 13, 2011 | 09:15 PM
Mustang5L5's Avatar
That's a slipping trans. You can try and change the fluid and see if that saves it, but more than likely it's burning up internally and too late.
Time to take it to a shop that specializes in transmission repair.
Old Jan 13, 2011 | 10:08 PM
NFSP G35's Avatar
? = 2B || !2B
Oops
Too used to GM vehicles!
Freeman186
Sep 6, 2023 10:07 AM
magnetism80
Feb 1, 2019 10:00 AM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
Gwhut?
Drivetrain
Sep 6, 2015 10:07 AM
Jnm07
Sep 5, 2015 01:16 AM
