FS[NorCal]: Auto to 6-speed swap kit
Someone who know these cars should be able to do it in a day or two. The most likely outcome will be it taking a week or two to do the work. As for how much, it really depends on who you take it to, but chances are a shop will charge anywhere from $500-2k depending on how well you know the owner. I can't really tell you 100%. If you are local shoot me a PM, I may be able to do the install for you.
Coupe parts needed.
Do you have the power steering cooler with all hard & soft lines going to the pass side ( by pump & rez )?
Windshield washer bottle, pump & neck.
Pass side interior grab handle ( black )
Front belts ( black ) not triggered
Pass side harness ( section ) for headlight, side marker & fans.
Thanks
Mike
Thanks
Mike
Coupe parts needed.
Thanks
Mike
Thanks
Mike
Shiftknob is sold.
