amz oil atf compatibable with matic j
Old Apr 11, 2011 | 10:46 PM
newlo-g35's Avatar
Ok so this may sound dumb but it was a long day.
started diong my oil change on my 03 g35 coupe, climbed under the car for the first time, saw what I thought was a drain plug for the oil pan and removed it.
unfortunately it was the drain plug for my transmition reservoir.
After feeling like a complete idiot cuz it was sunday and my dealer was closed
I found amz oil synthetic atf fluid that is compatible with matic j fluid
re filled my tranny and did the oil change.
I will say though that with the amz oil in the tranny it shifts quicker and smoother
Old Apr 11, 2011 | 11:05 PM
abcdo4dkIdjkm's Avatar
I am not familiar with the amzoil oil. But you should be ok. I have read however that these transmissions are very sensitive to transmission oils. So I would always err on the side of caution and just stick to the OEM fluid.(for the future)
Old Apr 11, 2011 | 11:15 PM
newlo-g35's Avatar
thanks man
I have looked everywhere and found the same thing that you must use matic j,
however the amz does list it as bieng compatibable,
mabye I will check it out for deterioiration in a week to see
thanks
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
