Speed Sensor Location on 06 G35 Coupe 6MT
Old May 19, 2012 | 03:59 PM
Boostgod's Avatar
My friend has an 06 G Coupe 6MT and his speedo is acting wonky. I want to check the connector on the sensor. Where is it located? Is it on the transmission or the rear diff?
Thanks in Advance.
Old May 19, 2012 | 04:06 PM
Footballmania32's Avatar
The ABS/speed sensors are located on the rear diff. It is one harness with one sensor on each stub axle coming out of the diff fastened by a size 12 bolt. The fronts are located behind the hub. However, iirc the actual speed may be determined from the front sensors reading the rotation of the wheel. Lmk if your have any more questions!
-Sean
Old May 19, 2012 | 04:41 PM
Boostgod's Avatar
On my S2000 there is a speed sensor on the tranny. Can you elaborate more on this, location / what sensor does what, and which reads speed.
Old May 21, 2012 | 09:36 PM
Boostgod's Avatar
bump for more info.
Old Jun 6, 2016 | 10:32 AM
dsheldon924's Avatar
yikes
Looks like another electronics malfunction that goes unanswered with the G35.... the saga continues
nervseele
Engine - Exhaust
Jan 17, 2016 01:02 PM
R350k5
Oct 1, 2015 08:41 PM
NemesisGee
Aug 11, 2015 07:10 PM
vstypicals
Jul 20, 2015 10:55 PM
nervseele
Jul 17, 2015 11:21 PM
