Exedy OEM Clutch + ACT Flywheel long term updates?
Old Feb 27, 2013 | 07:53 PM
oakpwr's Avatar
I'm getting ready to order a new clutch/flywheel and wanted to see how your aftermarket ones are holding up. I was all ready to pull the trigger on the exedy/act combo and talked to one of the techs. He said that there are always some concerns on the aftermarket combos and that he saw one that had a problem where the spring fell out on the clutch.
He said that he would recommend going with a paired combo, ie act/act jwt/jwt etc. I'm trying to keep the clutch chatter down and that's why I was going to go with the act flywheel. The act clutch/flywheel combo seemed a lot pricier as well.
Any suggestions? I have read all the previous threads. Thanks.
Old May 11, 2013 | 10:20 PM
RA020526's Avatar
I am having the same questions as you were having.
Did you get any answers? What did you end up installing, and has it worked out well?
Thanks.
NemesisGee
Aug 11, 2015 07:10 PM
tiguy99
Jul 26, 2015 01:39 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
