Diff Change after 4 years
Last time I had my differential changed was probably about 4 years ago before I moved from Florida. Well, I just did it tonight and took a picture of my bolt and decided to upload it, so you can see how bad it was! I will definitely be doing this more often now since I plan on keeping this car for as long as possible. It had so much crud on it the pic doesn't even do justice of how it looked when I took it out.
Always a good idea to stay relatively close to recommended service intervals (which I think for the diff is something like 30k miles, but double check that, I'm still waking up). Mine was pretty bad when I first did it as well, around 75k. It's not terribly difficult to do and definitely worth keeping up with.
Little side note / piece of advice - when you're going to drain the fluid, always remove the fill bolt first. If you happen to strip or round off that bolt, you want it to happen while the fluid is still in there, not after you've drained it!
edwinisdumb15
SOCAL Meetings & Events
Aug 3, 2015 10:42 PM
