06 g35 mt6 making clutch noises
Old Nov 27, 2017 | 06:04 PM
hadi's g35's Avatar
Angry 06 g35 mt6 making clutch noises
i recently bought a 2006 infiniti g35 manual today as i got home from school i stepped out of the car and i had the hand break on the car was in neutral i could hear the clutch making a wierd noise the noise goes away when i step on the clutch it makes a noise as if something is rattling inside thanks
Old Nov 27, 2017 | 07:13 PM
cswlightning's Avatar
You're okay, this is normal, assuming it's a fairly quiet noise and doesn't sound like something is about to fall off.
Old Nov 30, 2017 | 11:54 AM
Dannyb2134's Avatar
This sound is normal to an extent, here’s what to do if it’s too loud
My 2006 had this problem, it was really loud. I replaced the clutch and throw out bearing.
Cleaning the bellhousing of old clutch matter and all the grime, installing a new throw out bearing and greasing the input shaft will solve the issue.
You will hear the same noise with all new parts but it’s really quiet. That’s ok and normal!
!Important note! An aftermarket flywheel makes this noise more noticeable
