Howling noise at 40 MPH
Last weekend I replaced my differential bushings, which made the car drive like a dream.
Unfortunately afterwards I've started to notice a howling from the rear end of the car at 40-45 miles an hour, more pronounced when decelerating but also present when accelerating.
It changes in tone with speed.
Pushing the clutch in and/or putting trans in neutral has no effect.
Steering left and right has no effect
I remember the sound being there before but it was nowhere near as loud and omnipresent. Due to these reasons I believe it is my differential. Is there anything G35 specific or just general car knowledge I can do about this short of replacing or rebuilding my differential? Maybe I could have loosened something while whacking it with a hammer and blowtorching the rear bearings? I doubt it.
The noise goes away over 45 MPH though... Wouldn't a bad bearing just get louder? It's also less of a growl and more of a high pitched whine....
Loose pinion bearing preload is the closest I can find to the noise on youtube videos. I guess I could try dropping the diff again and torquing down the pinion nut to see if the noise goes away... My bet is the noise was always the same but now that the diff is actually connected to the chassis those vibrations are being transmitted to the subframe and I can hear them better.
G35xChicago
Nov 21, 2009 07:23 AM
Omar
Southern California
11
Dec 14, 2005 08:45 PM
