Questions for the dreaded p0300 code.
Good morning yall, I've got this 2003 g35 and let's be honest me and my buddies have been looking and guessing about this whole thing! So let me start off from the beginning. Purchased the G months ago. Random misfire.. replaced the no name Amazon plugs and coil packs with OEM plugs and coils. Helped but not completely. Swapped all camshaft position sensors and crank sensor. Same thing.. a little better but not 100%. Removed the leaking plenum spacer and installed a kinetix intake plenum. Helped but same same. Couldn't get a noid light to the injectors and seen where the harness is brittle so I got another injector harness and installed. Same. Just replaced the stock cats with aam test pipes because I seen where clogged cats would cause a similar problem. Removed and replaced. Also replacing the left downstream o2 sensor and both the right upstream and downstream because both were cross treaded in the gutted cats and thought would help with cylinders 2,4 and 6 plugs from fauling out again. Car ran beautifully for about 30 mins then back to page one. I'm at a loss for words and don't have enough crayons to even think about what to do next. Any help would be greatly appreciated. Thanks again.
Oh wow interesting. Do you know how that got figured out? Any sort of test that would figure it out? I'm having similar issues with the similar fixed but nothing is working. But mine is fine on cold start for about 5 minutes then starts to misfire and idle low and try to die
Definitely find a shop who has access to nissan hardware. We have a shop where I'm at that one of the lead techs decided to open his own shop. Found out about it and had him check it out.
Reggie Mompoint
Aug 1, 2017 07:12 PM
tasansal
Feb 29, 2012 12:57 AM
