HELP! JWT Clutch & Flywheel installed now she won't crank???!!!
Old Nov 10, 2005 | 06:32 PM
ScottR's Avatar
Come in Randy or Neffster...I just had my JWT clutch and flywheel installed, and now it wont crank???!!! It just turns over, the local infiniti dealer said they may not have installed the flywheel corectly and the timing could be off. Did you guys or anyone else have this problem? Man, my luck sux!
Old Nov 10, 2005 | 07:52 PM
neffster's Avatar
That's odd. First thing I'd ask is what did they unplug to do the install.
Also, go STRAIGHT to my350z.com Technical & Modification Forum and copy this thread.
good luck.
Old Nov 10, 2005 | 07:57 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
i am no expert...
but you can only start the car with the clutch pedal depressed.
maybe when they installed the new clutch/flywheel, it was not aligned properly causing the car to think the clutch and transmission is still engaged, or something else is causing to think the clutch pedal is not being depressed.
Old Nov 10, 2005 | 08:23 PM
nismo pete's Avatar
The flywheel can go on many ways but there is only 1 correct way for it to go on so that the crank angle sensor slots are in the correct place.
Sorry mate but out she comes again
Old Nov 10, 2005 | 08:33 PM
Julian's Avatar
Thats exactly what happened,or they didnt install or damaged the crank position sensor.
MRC MOTORSPORTS
ALL THE FASTEST G'S ARE BUILT AT MRC'S
G35 Driver's OFFICIAL UTEC AND TURBO XS DEALER
UTEC INSIDE
Old Nov 10, 2005 | 09:15 PM
drsifu1's Avatar
Staff ALUMNI
20 Year Member
yeah..what they said
Old Nov 10, 2005 | 11:26 PM
ScottR's Avatar
Thanks for the insight guys, the tranny is on a jack as we speak I'll have them check first thing in the morning. Keep your fingers crossed. If it's something they damged do you think we could start a bail ScottR out of jail fund?
Old Nov 11, 2005 | 01:49 AM
DaveB's Avatar
Crank position sensor.
Old Nov 11, 2005 | 12:04 PM
ScottR's Avatar
Well, shes running! Turns out the "technician" and I use that term loosley...istalled the dowell pin on the altima/maxima side not the G/Z side that was clearly marked in the istructions that came with the flywheel. In turn obviously the crank sensor wasn't aligned properly. Hope this helps anyone in the future that may have an incompetent tech install their JWT set up
Old Nov 11, 2005 | 12:37 PM
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
+1^ Sorry, I just saw this thread...glad it all worked out...
Old Nov 11, 2005 | 01:32 PM
ScottR's Avatar
Thanks guys! Just took her out for the first drive...UNBELIEVABLE!!! I didn't realize how bad my stock clutch was. The chatter is very minimal, revs VERY quick! Pedal releases just a couple of inches off the floor, and pedal feel seems lighter. Very happy with the mod thanks again for all of your help guys!
11bEMT
May 27, 2022 03:13 PM
zcherub
Aug 30, 2015 05:04 PM
EPG35
Aug 16, 2015 04:52 PM
dimentio1
Aug 16, 2015 11:47 AM
neight
Drivetrain
Jul 28, 2015 04:47 PM
