Koyo 36mm radiator and GTM fan/shroud
Jan 13, 2011 | 11:34 AM
payment Sent Steve in full for both radiator and shroud kit
Jan 27, 2011 | 03:51 PM
Racing Thermostat Needed?
Quote: It looks like you would have to purchase 2 Fan Relay Harness and I will confirm that with Rob as well as with Sam tomorrow.
On the GTM weblink that you provided that contained the Fan Relay Harness, directly below is a photo of the Spal PWM Automatic Programmable Fan Controller which cost $164.95. The Spal PWM Automatic Programmable Fan Controller allows the user to set the temperature at which the fan turns on. The Fan Relay Harness Does Not allow user to set the temperature at which the fan turns on. I wanted to clarify this so that there's no misunderstanding. Also I purchased 2 of the Spal PWM Automatic Programmable Fan Controllers and asked Rob to set the Spal Module temps at 185F for the low temperature setting and 195F for the high temperature setting. Both Fans do turn on when using the A/C.
For more product information on the Spal PWM Automatic Programmable Fan Controllers check out this weblink => http://www.spalusa.com/store/main.as...tem=FAN-PWM-V3
I have a Mishimoto Racing thermostat if that helps any? Used for three months...
Jan 27, 2011 | 05:29 PM
Quote: I have a Mishimoto Racing thermostat if that helps any? Used for three months...
that isnt related to what we were talking about....on the Koyo Radiator And GTM Fan Shroud you have 2 Fans..SPAL sales a fully programmable module that lets you control the Temperature at which the fans come on....outside of what the thermostat does. With that being said I have the nismo thermostat anyways. I just dont have a FAN Shroud on my current KOYO I am running 52mm racing radiator therefore my car starts to overheat in stop and go traffic
Feb 10, 2011 | 03:36 PM
is this rad and fan still available?
Feb 10, 2011 | 03:39 PM
Quote: is this rad and fan still available?
Nope its installed on my car now. I took off my Koyo 52mm one with meradyne 12"fans so I could have a shroud.
