Engine - Complete Motors Complete Motors & Motor Parts; pistons, blocks, cranks, cams etc.
FS: Built short block brand new
Old May 11, 2011 | 11:36 AM
Nismo G's Avatar
I am going a different route with my turbo kit so i am going to sell the short block i have been working on.
Right now the block is naked. I want to be able to put the proper pistons in it for someone if they want a high compression motor.
I can put pictures up, but they are just of the block so its nothing special. Pistons will be ordered depending on which compression is desired. If you need timing components (chains, guides, tensioners) i can provide those as well for a substantial discount versus going to your dealer.
Short block:
ARP main studs
Eagle Rods
Wiseco Pistons 8 : 8 : 1 or 11 : 0 : 1
ACL main and rod bearings
Block disassembled, cleaned, machined to pistons, and balanced
I will need your core as well.
Asking $3000.00
Old May 22, 2011 | 12:09 PM
LisbonsG35's Avatar
A little pricey or i would definantly pick this up... GLWS!!! Sounds like a nice block
Old May 22, 2011 | 12:54 PM
Nismo G's Avatar
Shoot me an offer!
Old May 24, 2011 | 01:57 PM
anubisblk38's Avatar
I have some questions about it I'll pm you.
Old Jun 3, 2011 | 11:10 AM
biggerandbetter's Avatar
are you set on this price? Im interested, but wouldnt want to spend this much. A few of the vendors have the shortblocks right now for $2600.
Who is doing the machine work/assembly of the block? And my last question, is can you ship it to 68134?
Old Jun 3, 2011 | 11:50 AM
Nismo G's Avatar
I am doing the assembly and a shop called bad iron is doing the machining and balancing. I haven't seen a short block for sale that has all the parts i listed for 2600. Possibly rods, pistons and maybe bolts, but i haven't seen rods, pistons, bolts, and bearings assembled and shipped for 2600...?
Old Jun 7, 2011 | 09:26 AM
Import parts pro has the packages for the short block fully assembled.
Stage 1 Short Block Package:
Wiseco Pistons .020 over
Eagle Rods
ARP Rod Bolts
Block inspected and cleaned
Block redecked
Block Bored and Honed using a Torque Plate
Rotating assembly balanced
Crank magnafluxed and the journals micro-polished
New Moly coated race Rod and Main bearings installed
Block assembled
This package runs only $2600 and can be purchased or get to get more details click
Old Jun 7, 2011 | 11:34 AM
Nismo G's Avatar
Pretty Decent price! If you are interested in me building you one for cheaper send me a PM.
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
