Engine - Complete Motors Complete Motors & Motor Parts; pistons, blocks, cranks, cams etc.
FS: Stainless Solid Motor Mounts !!!
Old May 25, 2011 | 02:50 PM
QuadCam's Avatar
I am selling a pair of custom made Stainless Steel Motor Mounts for the G35/350Z. I commisioned a fabrication shop to make these for my car. The design of these motor mounts allows you to use the same nuts as the OEM motor mounts, making installation a breeze! The mounts are made of 304 Alloy Stainless Steel Schedule 40 Pipe with studs welded into each end plate. Nissan uses studs on the OEM mounts to attach to the motor and chassis; it is a better design than other "through bolt" mounts. These mounts are fully tig welded and give you much greater area/access when working on your car. Ride quality is similar to stock; these engines are so smooth that you don't get extra vibrations when using solid mounts. Also, the car feels more responsive to throttle inputs when using these motor mounts. I used them for around 2 years and loved them. I have had my fun with my car and have now converted it back to stock. Deing that they are stainless steel, the mounts still look brand new (that's the beauty of stainless!)
PRICE: $65 plus shipping.
Old May 25, 2011 | 03:12 PM
TIAN's Avatar
Hold The Line
Please update with username and date per forum rules. Thanks
Old May 25, 2011 | 03:33 PM
QuadCam's Avatar
I'm not sure I'm following you....
update my username and date??? where?
Old May 25, 2011 | 03:35 PM
TIAN's Avatar
Hold The Line
You need a handwritten sign with your username and date next to the item you are selling per forum rules
Old May 25, 2011 | 04:09 PM
QuadCam's Avatar
got it. sorry about the confusion. I haven't been on the boards for awhile. I went ahead and updated the original post.
Old May 25, 2011 | 04:26 PM
redline485's Avatar
very tempting. they dont have the vibrations like the poly mounts alot of cars use?
Old May 25, 2011 | 04:48 PM
QuadCam's Avatar
Just sold to a guy on my350z.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
NailBomb
Oct 28, 2015 07:53 AM
alessandro
Oct 8, 2015 09:29 AM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
master111
Sep 25, 2015 08:32 PM
