Engine - Complete Motors Complete Motors & Motor Parts; pistons, blocks, cranks, cams etc.
WTB: A heap of forged internals
Old Jul 25, 2011 | 08:14 AM
R6n350GT's Avatar
Hi Venders, I am wanting to buy as much from the one vendor as possible
Here is what i need for my 03 VQ35DE
Wiseco Pistons 8.5:1 + Rings
Eagle H Beam Rods
ACL Race Rod/Main/Thrust Washers & Washers
ARP Main studs
AAM Throttle Body Spacer
OEM Parts
Welsch Plugs
HR Head studs
HR Head gasket
Water pump
Overhaul gasket set
Timing Chain upper and lower
Tensioners
twin plate clutch of some sort + throw out bearing + pilot bearing + ss line (anything else that needs replacing? Slave cylinder?)
I am thinking about cams + springs + retainers but depending on prices above will depend on this.
Please get back to me on all of this asap, engine is almost stripped and will be machined this week, as im in Australia i may be using Shipito as they have fantastic rates so shipping price to CA 90503 Or Australia 4037 if you have good rates.
Old Aug 31, 2011 | 02:18 AM
doreamon50's Avatar
I have a set of cp piston 8.5:1 brand new. Pm me if you are interested.
Old Aug 31, 2011 | 07:32 AM
R6n350GT's Avatar
Got it all from Z1Performance thanks.
But after oil cooler
Fuel return system
seagrasser
May 3, 2022 09:43 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
bigmike
Sep 17, 2015 01:58 PM
