Engine - Complete Motors Complete Motors & Motor Parts; pistons, blocks, cranks, cams etc.
FS: VQ35DE partout
Old Jul 19, 2012 | 10:07 PM
  #31
ANDRADE1's Avatar
the lower engine cover right under the engine. the center big cover that secures to the front bumper.
thanks
Tony
Old Jul 19, 2012 | 10:10 PM
  #32
ANDRADE1's Avatar
the lower engine cover right under the engine. it is attached to the front bumper.
thanks
Tony
Old Jul 19, 2012 | 10:18 PM
  #33
pghg35sedan's Avatar
I dont actually....you could probably check the exterior body forsale section......im sure one of those guys will have something for you (my also search for skid plate or factory/oem skidplate never heard it called a lower engine cover) thanks for asking me and goodluck finding what you need!
Old Aug 7, 2012 | 02:39 PM
  #34
bump
Old Aug 8, 2012 | 08:45 PM
  #35
lucid215's Avatar
2 coilpacks shipped to 37042? if you still have them by the 15th ill snag them up.
Old Aug 12, 2012 | 11:14 PM
  #36
r1forever80's Avatar
Still have the engine harness from the 6mt? if so does it have the wideband connections on the o2 sensors in the headers? thanks
Old Aug 13, 2012 | 02:05 PM
  #37
I do still havde the harness......I'll check to make sure the o2 sensor harness is attached and ill PM you...Thanks!
Old Aug 13, 2012 | 02:22 PM
  #38
Ok thanks. The o2 sensors in the headers need to be the ones with 6 wires like wide band sensors. I got a harness with the old style 4 wire
Old Aug 13, 2012 | 07:24 PM
  #39
Just let me know what u find. I'll buy it ASAP if it's the correct one. Would like to get it by friday
Old Aug 14, 2012 | 10:00 AM
  #40
G35X_204's Avatar
do you have an MD plenum spacer? and any pics on the side skirts you mention?
Old Aug 21, 2012 | 02:33 PM
  #41
bump
Old Aug 21, 2012 | 04:12 PM
  #42
Fijianassassin's Avatar
Did you get rid of your cam sensor bank 2 with the harness??
Old Sep 12, 2012 | 02:12 AM
  #43
R6n350GT's Avatar
Heads still ? Do you have the Camshaft caps and valve stems etc ?
Old Sep 12, 2012 | 07:31 AM
  #44
Yes I still have the heads...they are not missing any parts
Old Sep 18, 2012 | 08:42 AM
  #45
bump
