DIY: Spark plug change
Old Apr 13, 2016 | 07:06 PM
  #286
abrecos's Avatar
Guys changing spark plugs does not going to improve your fuel economy nor give you any performance boost,etc.its just give your engine a stable efficient combustion by providing high quality spark,that is all.You just need to follow the spark plugs changing interval,in the case with 2008 Infiniti G35 its 105000 miles.Denso iridium long life the best choice.
Old Apr 16, 2016 | 01:14 AM
  #287
Sean13's Avatar
great write up, definitely will do my very soon!!! thanks
Old Apr 19, 2016 | 01:20 AM
  #288
JohnnysG35's Avatar
Great video
awesome step by step thanks man
Old Apr 27, 2016 | 09:56 PM
  #289
Frankieg35's Avatar
I'm due for this, gonna do a plenum spacer while I'm in there..
Old Apr 29, 2017 | 01:15 PM
  #290
mtdurham's Avatar
Here it is in a pdf format so you can print it out and have it with you under the hood.
File Type: pdf
Old Oct 9, 2020 | 02:30 AM
  #291
Groat's Avatar
Black G35 Coupe
Would a 5/8" spark plug socket fit? it's the magnetic kind, so if it is 0.125 mm to large, would that still work?
Old Oct 9, 2020 | 02:54 PM
  #292
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Yes.
Old Apr 17, 2022 | 04:29 PM
  #293
isaac sabino's Avatar
infinite g35 coupe
for the wires on spark plug 4 and 6 do they cross? also i did a spark plug change on mine and i used these spark plugs from auto-zone i put everything back together and i had bad idle the rpms would drop and the car will die do you have a clue what i did? also my ignition coils dont seal they seem to keep popping up?
mtlruss
Dec 20, 2015 01:51 PM
JoeMac
Aug 20, 2015 10:17 AM
linedr89
Aug 17, 2015 05:11 PM
yassy
Aug 9, 2015 07:31 PM
wuppiedog
Aug 7, 2015 11:16 AM
You have already rated this thread Rating: Thread Rating: 5 votes, 4.80 average.
