CEL after installing plenum spacer
Old Jun 17, 2006 | 01:47 AM
bikesbikes's Avatar
I got a CEL after installing a 5/16 copper iso themal plenum spacer. I didn't do the gas pedal reset after installing it. I decided to pass by the dealer to get it checked out. Turns out that it's the throtle position sensor that set the light off. They "cleared" the light but I assume that is not a reset.
Just wondering if others had the same throtle sensor issue or another issue after installing the spacer.
Thanks in advance...
Old Jun 17, 2006 | 01:59 AM
SWAT311's Avatar
Not here.. no problems what so ever..
Old Jun 17, 2006 | 12:24 PM
RBull's Avatar
Rated M
Yes I did since I did not disconnect the battery negative terminal before starting the job. I gave it the overnight disconnect and everything was fine.
Old Jun 17, 2006 | 12:26 PM
2FastG354U's Avatar
I had mine installed yesterday and I have no problems.
Old Jun 17, 2006 | 01:32 PM
g35rcr's Avatar
you only get that if you mess with the throttle body plate during the install
Old Jun 18, 2006 | 12:43 AM
bikesbikes's Avatar
I did disconnect the battery and I didn't mess with the plate. I tried doin the ecu reset procedure but my timing must have been off. I'll try the overnight battery disconnect.
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
Raven7
Aug 14, 2015 04:40 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
