Does ur G make a "click" sound when u back in reverse
Old Jul 12, 2006 | 12:22 PM
tommyz9's Avatar
I have a 05. I am noticing when I shift to reverse, I hear this " click " sound. Pretty loud. I am not sure if it is coming from the transmission or from the exhaust. It didn't make this noise when I first bought the car. Anyone else having this issue? Don't have a chance to have the dealer check it out yet.
Thanks.
Old Jul 12, 2006 | 12:34 PM
drunkin master's Avatar
Is your car stock?
It could be lots of things. Many people on the forum hear many noises.
When you have time take it to the dealer and show them.
Old Jul 12, 2006 | 12:38 PM
denverinfiniti's Avatar
Its more than likely a click from your axles. Pretty much ALL G's do it. When you get a chance take it to a dealer. Theres a TSB for it
Old Jul 12, 2006 | 12:47 PM
tommyz9's Avatar
thanks guys for the info. Yes, my g is stock. I will drop it to the dealer.
03silver's Avatar
Strange is i just got mine back from the dealer for a recall and fluids and now I get the same click when I put it in reverse. I noticed it right away. It happens 60% of the time???? I thought it sounded a bit strange, but thought nothing of it. I'm pretty sure it's something the dealership did to my car.
this is what got done...
fuel lines (recall)
engine, trans, and diff flush
new belts
brake inspection
Now I get the same click. Could it be the diff? Hope this helps and our clicks goes away.
Old Jul 12, 2006 | 12:48 PM
JEVERYDAY's Avatar
Mine def does not. Doesnt sound good, might be a TSB
Old Jul 12, 2006 | 01:31 PM
Yeah defiantely sounds like the axle click. We seriously do three or four of them a day
Old Jul 12, 2006 | 01:35 PM
alan21's Avatar
it is the locking nut on the rear axle just tell the dealership to tighten it
Old Jul 12, 2006 | 01:38 PM
03silver's Avatar
What will happen if you don't fix it?
Old Jul 12, 2006 | 02:02 PM
tommyz9's Avatar
I only have 10K on my G and it is pretty loud. I will drop it off to the dealer. I will report what the dealer say. thanks. My car is stock. It is happening everything I put in reverse.
Old Jul 12, 2006 | 02:04 PM
BlackOutG's Avatar
take it to the dealer and they will fix it for your for free.
it happen to my car too.
Old Jul 12, 2006 | 04:05 PM
Omeezy's Avatar
My car is at the dealership for that same thing now. They said that they lubed it up and tightented some things and that it should be taken care of.
Old Jul 12, 2006 | 04:15 PM
Nothing is loose, so no worries if you dont get it fixed. Besides the noise that is. We remove the axles and lubed the plate that sits against the hub. Thats about it. You can get away with just loosening the main nut and retightening it though. Thats what we did before the ITB came out
Old Jul 12, 2006 | 05:37 PM
UFGatorG35's Avatar
No noise from mine. Check your wheel well, you might have "picked up" the neighbor's cat
Old Jul 12, 2006 | 06:32 PM
TURBOTOM's Avatar
a.k.a kleicoupe
I had this fixed, and in a week the noise came back!!
Im bringin it in again, so we will see what happens...
