Oil changes
Old Sep 17, 2002 | 03:14 PM
Cameron38's Avatar
Re: Oil changes
I talked to my mechanic yesterday about when I should do the first oil change on my Coupe when I get it. He said about 2000 miles. He recommended I switch it over to synthetic oil.
Old Sep 17, 2002 | 03:58 PM
dyenboy's Avatar
Registered
Re: Oil changes
I changed mine on 1000 miiles as well, I heard that it clears like loose stuff from ur engine and I recommened it.
Old Sep 17, 2002 | 05:42 PM
EhhFour's Avatar
Re: Oil changes
I'm currently driving an A4 - Audi strongly recommends NOT changing the oil early so that the rings (and other bits) will seat properly. I've read this elsewhere as well and imagine that this is the case with many or all engines.
Old Sep 17, 2002 | 07:37 PM
Gordgee's Avatar
Administrator
Re: Oil changes
My Infiniti dealer also does not recommend the 1st oil change until at least 4000 miles. Says that the original oil is a special blend that helps with the break-in. Synthetics are also not recommended until at least 8-12k miles as they are too slippery for remainder of break-in. The cars that start with synthetics (Vette, M-Bs, Vipers, etc) have an engine that is designed wirh synthetics in mind ie. tolerances, etc.
Pearl White/Graphite, loaded except Aero & Navigation
Old Jan 9, 2012 | 02:30 AM
dukehotty's Avatar
Rise!
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
