Lightweight Flywheel and Clutch Installed But...
Old Aug 18, 2006 | 12:06 PM
Purcha's Avatar
Winter Boost Project '06
Exclamation Lightweight Flywheel and Clutch Installed But...
I just got my lightweight flywheel and clutch installed on my G. Under load my car makes a distinct rattle sound from about 1500-2500rpm and then stops. It seems like the clutch is making this sound or the flywheel may be unbalanced maybe? Can anyone give me some input on the subject matter. It would be greatly appreciated. Thanks.
Old Aug 18, 2006 | 02:33 PM
g35rcr's Avatar
lighter flywheels will make more noise, the stock flywheel had a dampener on it that helped with the noise...its normal
Old Aug 18, 2006 | 03:08 PM
DaveB's Avatar
It's normal. You're going to have to live with it.
Old Aug 18, 2006 | 03:13 PM
ttrank's Avatar
Grocery getter
It's normal. It is called "chatter".
The stock flywheel is dual-mass meaning there are two parts connected by springs to dampen the sound. The lightweight ones are a single piece that allows all the sound to go through it.
It's not hurting anything. Mine does it too. The installer should have warned you before doing it.
Old Aug 18, 2006 | 03:25 PM
Jeff92se's Avatar
Red Card Crew
Agreed. It might also go away after it's broken in. So make sure you break it in correctly
Old Aug 18, 2006 | 04:57 PM
sanastasiow's Avatar
Wild. I just bought a new 06' 6MT and it does the exact same thing. Only in 1st, and only at low rpm's. Sound is gone by about 2500, and sounds like a rattle...
Old Aug 21, 2006 | 11:04 AM
GT-Ron's Avatar
Purcha - Which flywheel/clutch combo did you use?
Old Aug 21, 2006 | 04:52 PM
Riker's Avatar
Same rattling noise happens on my 93 Vette. Went from dual mass flywheel ($1000 flywheel) to a single mass flywheel, (lighter and cheaper).
Old Aug 21, 2006 | 04:58 PM
Alan's Avatar
this is normal : ( it wont go away. my stock setup rattled a bit but when i had the jwt combo installed, it rattled even more.
Old Aug 21, 2006 | 06:38 PM
g35rcr's Avatar
if it really bothers you, you could dynomat your whole car to help dampen the sound
Old Aug 21, 2006 | 08:52 PM
kurzo's Avatar
Yeah, and make an already heavy car a lot heavier.
Old Aug 21, 2006 | 09:47 PM
DaveB's Avatar
It's no heavier than a Ferrari F430
Old Aug 21, 2006 | 09:56 PM
trey.hutcheson's Avatar
And it doesn't have the go power, handling, sound, well, *ANYTHING* of the f430 either
Old Aug 22, 2006 | 12:26 AM
edwin350z's Avatar
i have had jwt flywheel combo on my car for about 4 months and it seems to be getting louder.. wonder why though???
Old Aug 27, 2006 | 05:26 AM
kurzo's Avatar
The F430 has better power:weight, so that's not a relevant comparison
