View Poll Results: if I'm NOT running lean (non-revup)... (plz read below before voting)
MD 5/16" Iso Thermal spacers
30.00%
MREV2
16.00%
Combo of both
27
54.00%
Voters: 50. You may not vote on this poll
Spacer or Spacer/MREV2 combo?
Old Sep 1, 2006 | 11:16 PM
ChiefyMan's Avatar
Ok, yes, I know you're thinking SEARCH!!!
How, hold on. I know there's a possibility of running lean on nonrevup's (03 5AT sedan here) w/ the combo. However, I'm going to dyno to get my current numbers as well as find out if I'm running lean or not. If I'm not, would you suggest both in a combo? I've heard some people say ONLY to go w/ one or the other even if I'm not running lean, so I just want to get a general idea.. thanks!
Old Sep 2, 2006 | 12:18 AM
ttrank's Avatar
Grocery getter
There is almost a 0% chance the spacer would do that.
Old Sep 2, 2006 | 01:56 AM
dTor's Avatar
combo.
Old Sep 2, 2006 | 10:10 PM
jimmykce1's Avatar
According to EverythingG35, if your running an automatic (nonRev up engine) you should only run the MREV2 unless you have a fuel management on your car. If you have a 6Speed manual (rev up engine) you can run both.
Old Sep 2, 2006 | 10:13 PM
Andy2434's Avatar
The MREV2 will afford total stealth. The dealer will never know that you have it on.
Old Sep 3, 2006 | 12:25 AM
ChiefyMan's Avatar
That's not to much of my worry - I'm outta warranty anyway.
I'm just trying to figure out that as long am I'm not running lean (which, from what I understand, means I wont w/ the combo even on non-revup...) if I should do combo or just one or the other...
Old Sep 3, 2006 | 01:17 AM
V35 Skyline GT's Avatar
6MT Coupe
If you have a rev up engine (6mt) you can run both.
If only nonrev-up, (5at) only one or the other.
The reason you can run both on the rev-up is, the ecu has better parameters/programmed fuel mapping to compensate for this and not go lean, though you're about maximum of what the ecu fuel mapping can compensate for with that combo.
With nonrev-up, you'd be well beyond the ecu's fuel mapping parameters to compensate for the large increase in air volume/velocity with that combo and you will run lean, even if you're not lean now without that combo.
My vote is the mrev2 only for your nonrev-up VQ.
Old Sep 3, 2006 | 09:42 AM
Nismo G's Avatar
I agree its a non revup motor so i would just run the 5/16 spacer that will add enough power (unless you want a ECU reflash by technosquare then you can run both).
If you dont want a new ECU or reflash you might need a airflow controler or piggy back system if you have a after market air intake with the spacer it may cause you to run lean, but get it dynoed first and see the results the base it off of that.
Old Sep 3, 2006 | 04:31 PM
ChiefyMan's Avatar
Nismo G, I see you got a CTS V race car as your avatar. Nice!
Anyway, ya, I got the Stillen intake and exhaust.
Old Sep 4, 2006 | 01:19 PM
O HELLA JDM's Avatar
aite i might sound stupid...but i seriously dont know what running lean means ...i was goin to get a MD spacer, but i have a injen cai....so would that make my car run lean...have an 05 G35C AT???
Old Sep 4, 2006 | 05:35 PM
ChiefyMan's Avatar
"Running lean" in basic terms means to much air for the fuel mixture... running rich is the oppose, to much fuel for the air mixture. It's all calls the AFR, or Air/Fuel Ratio.
Old Sep 4, 2006 | 05:48 PM
glennp_1999's Avatar
The spacer won't do anything for your car since you have a 05 5AT. Your best bet is to go with an Mrev you will have more gains with this setup than just the spacer. Actually some lost power with just the spacer for the 05-06 yr model.
Old Sep 4, 2006 | 05:55 PM
Get the 5/16th (torque) or 1/2 in. (top end) spacer together with the isothermal gasket (cools the intake plenum). My car is back to stock now and I miss my setup the engine is quiet and I have no top end power. 70 going to 100 use to be a snap now it feels like the car is laboring just to accelerate to that speed.
Old Sep 6, 2006 | 02:05 PM
maxpower's Avatar
I thought that the spacer was fine on the 05 AT (280hp/270tq), just not the rev up MT
Old Sep 6, 2006 | 08:00 PM
Andy2434's Avatar
Yes, that is correct. The MD spacers will work just fine on the non RevUp engines. The spacer alone will afford little, if anything, on the RevUp engines.
