shifting from 1-2
Old Nov 2, 2006 | 02:30 PM
souLifted's Avatar
shifting from 1-2
when my coupe is cold, its hard for me to shift from 1st to 2nd and makes a noise. but its fine when its warm. i was jw if anyone else has this problem too and if there's something messed up in my tranny.
Old Nov 2, 2006 | 02:36 PM
silver g's Avatar
What kind of noise?
Old Nov 2, 2006 | 03:13 PM
GreenGoblin's Avatar
The goblin resurrection
I dont think mine makes a noise but I will check
Old Nov 2, 2006 | 04:03 PM
nghiars's Avatar
its our ****ty transmission... shifting is rarely ever smooth from 1st to 2nd
Old Nov 2, 2006 | 07:51 PM
obender66's Avatar
Yeah, same problem here. But It seems to shift better when you pull lever not towards 6 o'clock going into second, but somewhat 6:30-ish-towards yourself.
Old Nov 3, 2006 | 01:25 AM
souLifted's Avatar
its a clank noise and its just hard putting it in the gear itself, like its not smooth. but, i realized that its perfectly fine at a certain rpm, around 3-4k and when the car is warm.
Old Nov 3, 2006 | 09:37 AM
hwy_star's Avatar
mine is very tempremental, sometimes it goes right in, sometimes it takes a few seconds. I dont force it into 2nd - if you apply a little pressure and it doesnt feel like its going to go, just wait a few seconds and it will slide right in. I guess its the syncro.
Old Nov 3, 2006 | 09:10 PM
silver g's Avatar
How old is your car? I had this problem when my car was new. I now have 55,000 miles on the car and the tranny shifts very smoothly. Much smoother than when I first got the car.
Old Nov 4, 2006 | 01:53 AM
G35-4Life's Avatar
I have a post on this as well. I've got the same problem. How old is your car? Mine is new and I hope that this goes away. As you say, as long as I'm in the 3000RPM range when I shift it is usually better. So I am hoping that it is a synchronization problem that will go away as the car gets broken in.
Old Nov 4, 2006 | 01:56 AM
Klubbheads's Avatar
I don't have that problem, I can shift mine with only 2 fingers.
Old Nov 4, 2006 | 07:59 PM
csdstudio's Avatar
I just had my tranny fluid flushed and now I have all the problems above, thanks alot dealer. The tranny was pefect for the first 33K miles, now it whines and jams hard into the slots. Plus it feel like the tranny is putting tons of drag on the engine. While in neutral and the engine revving at 1500rpm if I release the clutch the RPMs drop to 1000. That to me indicates the input shaft is putting tons of drag on the engine itself. I bet the moron forgot to put the new tranny fluid in after draining the old.
Old Nov 5, 2006 | 04:10 AM
BLUE V35's Avatar
Sounds like they put the wrong grade oil in it.
Old Nov 5, 2006 | 11:41 AM
csdstudio's Avatar
Does anyone know what grade/weight oil they are supposed to put in the tranny? I guess I should have to check up on the dealer now. F'n steamed, I am.
Oh, and the differential whines, so I'm guessing the friggen tech swapped the fluids and put the 90W **** in the tranny, and the lightweight oil in the diff. Now I'm even more pissed.
Old Nov 5, 2006 | 11:22 PM
BLUE V35's Avatar
75w-85
Thats what it says in the manual
Old Nov 5, 2006 | 11:29 PM
ttrank's Avatar
Grocery getter
I have had problems with the 1-2 with both my tranny's. It's more the POS synchros than anything else.
