Installed My kinetix plenum (questions)
Old Nov 14, 2006 | 02:55 AM
Klubbheads's Avatar
I bought the plenum used and the kinetix gasket was messed up so i had to use OEM one plus a silicon gasket (it withstands over 500°). Overall the car is pulling better and smoother. I have to go to the dragstrip to find that out though.
When i start the car i have to blip the throttle once for the car not to stall but after that it just stays about 600rpm idle and it is steady.
Now the question is:Is this something that the ECU will take some time to get used to or there is something wrong. Keep in mind the idle is very steady and there is no needle movement. The car runs perfect after that one blip of the throttle right after startup.
Old Nov 14, 2006 | 03:42 AM
richie's Avatar
I had the same problem after installing my mrev
After I performed the "Idle Air Volume Learning (Throttle Position Learning)" that fixed the problem. Give that a try... you should be able to find the instructions on how to do that somewhere on the board, but if you cant find it, download the motordyne instruction manual, its on the second to last page
http://motordyneengineering.com/manual.pdf
Just curious, did you disconnect the battery when you installed your plenum? My guess is that you didn't disconnect it....
Old Nov 14, 2006 | 04:10 AM
Klubbheads's Avatar
I did disconnect the battery and left it like that for 10 hours till the silicone dried.
Thanks a lot for the page, Im gonna give it a try tomarrow.
jsimonk
Dec 22, 2023 03:49 PM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
deathsupport
Canada
Aug 2, 2015 10:13 AM
