Stillen CAI fugged install
Old Nov 14, 2006 | 11:18 PM
steve465's Avatar
OK, I'm installing my Stillen CAI and the instructions say to use the OEM bolts to secure the MAF tube to the aluminum venturi ring. Getting everything to line up was a pain. I had to push the filter hard against the housing to get the holes to line up. I finally get the bolts threaded and almost get them tightened and two of them suddenly felt like they sort of broke free.
I don't know if I partially broke the bolts or if the threads in the aluminum venturi ring stripped. Has anybody had a problem with this????
Thanks for any input.
Old Nov 14, 2006 | 11:27 PM
bullseye's Avatar
That didn't sound good... Will the screws back out of the holes, or do they just turn in the hole without backing out? If they won't back out, then you may have stripped the hole(s). I don't remember having problems getting the holes to line up. I bought/installed this item on two different cars. I didn't have to strain or wrestle anything to get it installed. My point is, I'm not sure why you had to wrestle yours. I have never heard anyone complain about this before... Sorry I couldn't help.
Old Nov 14, 2006 | 11:29 PM
steve465's Avatar
Actually I got ticked and put it down. I'll see if I can back them out tomorrow.
Old Nov 15, 2006 | 02:30 PM
GreenGoblin's Avatar
The goblin resurrection
that doesnt sound right
Old Nov 15, 2006 | 03:34 PM
Skyline_G35's Avatar
English dude, English
Back out the screws. If they have little metal shavings in the threads then you stripped out the venturi ring. If that is the case, call up the CS Manager at Stillen and see if they can ship you out a new venturi ring.
You should have no issues lining up the holes. I would put in all four screws with a couple of turns of each and just keep doing that so that the pressure is even among all four of the bolts. Then just tighten it up so that it is snug. If you are afraid that they might back out, then buy some locktite and put it on the threads of the bolts.
EPG35
Aug 16, 2015 04:52 PM
Team STILLEN
Aug 10, 2015 08:17 PM
Racova
2nd Gen (V36) Sedan
Aug 8, 2015 10:21 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
sick_sixspeed
Tuner & Dyno
Jul 21, 2015 03:23 AM
