knocking noise when accelerating
Old Mar 24, 2007 | 10:53 PM
Skaterbasist's Avatar
Retired SuperMod
More importantly, around what RPM range does this happen?
Is it more common on the lower gears?
Old Mar 26, 2007 | 03:01 AM
G-MENTED's Avatar
the rpm range varies, but its usually around the lower rpms in the lower gears, mainly 2nd. my friends say that it sounds like its comin from the middle/rear part of the car, and not the front.
i just got an oil change and the oil level is normal.
Old Jan 17, 2010 | 07:16 PM
JacekPSUr6's Avatar
Bringing this back from the dead...I'm experiencing the same exact issue. 2003 Sedan 6MT. G-mented, has flushing the cooling system fixed this issue for you?
Old Sep 9, 2013 | 10:54 PM
twelfelt's Avatar
Yeah, I know this is a dead thread, but I figured I'd toss my two cents in. I have an 03 6MT coupe and I get the same thing every 6-8 months. For me it sounds like a slight rattle around 5500rpm - 6500rpm under hard load. I've found that it usually signals it's time to run SeaFoam through the fuel/intake system. That clears it right up for me. Not sure the cause, but that seems for fix it for a while.
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
