View Poll Results: headers and pully on a vortec sc
just do the pully i will get good ganes and sell headers
0%
other ?coments please
0%
Voters: 9. You may not vote on this poll
headers and pully
headers and pully
hi every one i have an 03 g35 with the vortec sc and exhaust
puting 335 whp in 2 weeks im puting the stage 2 pully on 9lbs bost
up from 6lbs
i was wondering if i should do dc sports headers at the same time witch i do own, im looking for 360-380 whp.
but are the headers worth the money of instal or can i get this gane from just the pully and a dyno tune?
up from 6lbs
The headers will def. not rob power. You will def. see a gain from them. When you put the smaller pulley on, you are forcing more air in. When you install the headers, you are letting more air out. The only part of the equation you are missing is more fuel, which could be fixed with a tune, fuel pump or injectors.
Install the headers and have a GOOD tuner tune the car for you . You might want the shop to look for boost leaks , or the serp pulley being to loose . At 6psi you are a little low on the boost . If you have the stock headers and cats on , the boost is off by 2 psi .
magnetism80
Jan 27, 2016 12:57 PM
lavtxa
Sep 21, 2015 11:51 AM
Albanian122
Engine - Exhaust
Sep 5, 2015 11:23 AM
