Engine Driven Radiator Fan
Old Dec 26, 2003 | 09:20 PM
RKG35's Avatar
I have a 2003.5 Sedan AT that has an engine driven radiator fan. Is there any advantage in changing this to an electric fan? Is this possible? Has anyone done this?
Thank you,
Rick
2003.5 Sedan 5A:
Desert Platinum/Graphite
Premium, Sport
Old Dec 26, 2003 | 09:30 PM
Gsedan35's Avatar
Re: Engine Driven Radiator Fan
It's been discussed before in depth. I just ran a search in this section ounder radiator fan and I found the posts. I'd post the results but this boards search engine doesn't allow for posting mass search results.
"i, for one, am not a fan of glory hounds."
Dang straight, it's all about the glory of helping. Who have you helped today?
Old Dec 26, 2003 | 11:27 PM
Msedanman's Avatar
O.F. Administrator
this is going back 6 months bro.. to get the live links just search for 'radiator fan' ....enjoy.
__________________________
Subject Forum Poster Posted on
Re: Engine Driven Radiator Fan Technical and Modifications Gsedan35 12/26/03 09:30 PM
Engine Driven Radiator Fan Technical and Modifications RKG35 12/26/03 09:20 PM
Re: Mods without More Sound Technical and Modifications DaveO 12/24/03 08:26 PM
Re: 350Z duct & Stillen Hi-flow Technical and Modifications DaveO 09/26/03 01:27 AM
Re: Please help with electric radiator fan info. Technical and Modifications gsedanman 08/24/03 11:57 PM
Re: Please help with electric radiator fan info. Technical and Modifications DaveO 08/24/03 10:16 PM
Re: Please help with electric radiator fan info. Technical and Modifications gsedanman 08/24/03 06:18 PM
Please help with electric radiator fan info. Technical and Modifications DaveO 08/24/03 05:32 PM
Re: Sedan radiator fan mechanical or electrical? Technical and Modifications DaveO 07/31/03 08:51 AM
Re: Sedan radiator fan mechanical or electrical? Technical and Modifications GIlovemycar 07/31/03 08:25 AM
Sedan radiator fan mechanical or electrical? Technical and Modifications DaveO 07/30/03 04:12 PM
Re: Engine Cover Technical and Modifications DaveO 07/16/03 06:53 PM
Re: Engine Cover Technical and Modifications DaveO 07/15/03 10:59 PM
<font color=red>G</font color=red>S<font color=green>M</font color=green>
<font color=red>G</font color=red>S<font color=green>M</font color=green> <font color=black>Silverstone Coupe</font color=black>
Old Dec 27, 2003 | 12:13 AM
DaveO's Avatar
RKG35,
Yes. Some "experts" say up to 15hp.
Yes it's possible.
I'm 85 to 90% done with the fan changeout project. Researching "stand alone" AT Sedan wiring as well as some personal issues have negatively impacted the project.
DaveO
2003 G35 Sedan - DP / Willow / AT / Premium / Sport
350Z Engine Cover, T-Stat & Air Duct / Stillen CAI
GG 7-Wire H-G Kit / TechnoSquare ECU
Street Edge TC / Stillen Exhaust System
Old Dec 30, 2003 | 12:19 PM
karlhungus's Avatar
I searched, but couldn't find any specific info. on how this was done. If anyone has completely retrofitted their 5AT sedan belt fan with an electric, please list part #'s, and any wiring diag. needed to do the job. I don't want to reinvent the wheel unless I have to. Also, I wonder if the factory 6MT sedan electric fan/shroud assy. will be a direct bolt on to the radiator? Should be easy to connect to the factory thermostat as well.
Old Dec 30, 2003 | 01:29 PM
DaveO's Avatar
karlhungus,
I guess there's several ways to do this. I've considered three.
Yes, the 350Z - G35 Coupe - G35 MT Sedan Radiator Fan Assembly is a direct bolt-on.
Not necessarily. The IPDM E/R fan control circuits and Engine Room Wiring Harness are different.
To date I have not been able to find the temp setting that kicks on the AT Sedan's Aux fan or the temp setting for the dual fan setup for that matter. Since the AT Sedan has a 180F thermostat and the others have a 170F thermostat, I'm believe there's at least 10F difference in when the ECU turns these fans on and off.
DaveO
Old Dec 30, 2003 | 03:31 PM
karlhungus's Avatar
Thanks,
Good to know that a direct bolt-on will work, now how much $$$$$? Probably too much. I think I could find a good aftermarket thermostat fan switch from FAL or others that would work. Bypassing the ECU seems like the best way to activate it at this point.
Old Dec 30, 2003 | 05:53 PM
DaveO's Avatar
Radiator Fan Assembly - Part # 21481-CD000
I've been quoted from the lower $300 range to over $400 from various Nissan & Infiniti Dealers. Of course you'll have to add shipping and tax to those numbers.
DaveO
Old Dec 30, 2003 | 07:29 PM
karlhungus's Avatar
Whoa,
Thats better than I could find. I just called the local dealer and he said $534.00 for the whole 6MT sedan assy. (dual fan motors, 2 fan blades, shroud, mounts.) Too rich for me to spend on 5-10 HP, but $250 would be more like it. Too bad FAL doesn't make a kit for the G yet. They have the model 210 kit for the I30, probably would work but be ugly unless you had really good fabrication skills for custom mounts etc. I think I'll wait for aftermarket.
Old Dec 31, 2003 | 11:40 AM
ekaz's Avatar
I have an '04 G35x sedan and there is no engine driven fan. Maybe someone can dig up part numbers and such quicker than I can while at work. I will look to see if I can find anything once I get home. Happy/Safe New Year to All.
Old Dec 31, 2003 | 11:49 AM
SoCalTed's Avatar
DaveO....
So if we were to change out the thermostat, would the MT fan assy work?
-Ted
'03 Sedan 5a: BS/G, Prem, Aero/Body, Sport, Nav
Click for MODS or Vote at Online Showoff
Old Dec 31, 2003 | 02:14 PM
DaveO's Avatar
Ted,
I don't have the MT Sedan t-stat information. I recommend you use the following Nissan part numbers.
Thermostat Part # 21200-4W010
Gasket Part # 13050-31U00
I'm sure Performance Nissan can supply a 350Z t-stat and gasket at a good price.
DaveO
Street Edge TC / Stillen Exhaust System<P ID="edit"><FONT class="small"><EM>Edited by DaveO on 12/31/03 11:16 AM.</EM></FONT></P>
Old Jan 9, 2004 | 12:03 AM
DaveO's Avatar
Here's a picture of my electric fan that I used to replace the mechanical fan on my AT Sedan.
DaveO
Street Edge TC / B&M Cooler / Stillen Exhaust
Old Jan 10, 2004 | 12:23 PM
DaveO's Avatar
E-Fan Project Status.
Another surprise - another difference! The dual radiator fan shroud will not directly mount on AT Sedan's lower radiator support assembly. The mounting points are totally different. Another assumption gone wrong. You'd think I'd have learned by now.
My e-fan is now mounted on the mechanical fan's shroud as shown in my picture above. I'm in the final stages of "tuning" the variable speed controller's start point and verifying proper operation.
DaveO
GG 7-Wire H-G Kit / TS ECU / E-Fan
KevinnnVo
Oct 14, 2024 04:33 PM
baker2795
Sep 2, 2015 06:00 PM
yassy
Aug 3, 2015 12:24 AM
joedaddy1
Jul 28, 2015 02:58 PM
