grounding kit help...
Old Dec 30, 2003 | 02:15 PM
YngPhllyKd's Avatar
i just got my stillen hyper grounding kit installed and i dont feel a difference at all. Not even a noticable amount of smoothness with the shifting. Has anyone installed the Stillen 7 Wire kit?
KhaL
Old Dec 30, 2003 | 03:31 PM
Triji's Avatar
Re: grounding kit help...
Make sure all the connections are made properly, I had mine installed at a local shop and they had it wired all a$$ backwards. I just took the whole thing off and re-wired it today, here is a map of the correct connection points. (disclaimer, this is not my engine but a great map for the grounding kit)
2004 Coupe, 5AT, Twilight blue / Willow int, K&N Typhoon CAI, Hyper Grounding Kit, Mtek Xenon Fog/High, Clear corners, Hypers, 18's, Aero, tint, Premium.
Old Dec 30, 2003 | 06:35 PM
Gordgee's Avatar
Administrator
Yes, that's a the GroundingGear™ install pic. It's "Copyrighted" © 2003 GroundingGear Ltd., so please just don't use it for commercial purposes, nor reproduce without authorization, Thanks. Feel free to link to it as posted on the thread though.
<font color=green>GroundingGear™ Equipped </font color=green>
Old Dec 30, 2003 | 07:15 PM
YngPhllyKd's Avatar
that 7th wire...where does that connect to?
KhaL
Old Dec 30, 2003 | 08:00 PM
Gordgee's Avatar
Administrator
The 7th wire connects directly to the transmission housing. Z-Xtreme is also now doing this on the 350Zs with good results.
Old Dec 30, 2003 | 09:25 PM
YngPhllyKd's Avatar
how bout that 8th wire? what's that all about?
KhaL
Old Dec 31, 2003 | 12:38 AM
Gordgee's Avatar
Administrator
That 8th wire isn't mine. Not sure what it's supposed to do. I usually only do extra wires for GroundingGear™ if it theoretically can benefit the performance. I know that at least one of our members has added about 11 wires I believe, but I'm not convinced that it's worthwhile to get carried away. There is an optimal number of wires for every car, usually 5 to 7, beyond which there are diminishing returns. I know a few locals that have used generic H-G kits on their Hondas, etc. and many of the grounding points they chose for their wires were questionable at best, sometimes being grounded to points with no continuity at all! Of course, if it's done purely to look 'cool' under the hood rather than for performance enhancement, they've served their purpose. This is the reason that the kits should be engineered to the application and why I don't do GroundingGear™ as a generic kit, and also the reason that GroundingGear™ is offered as a dealer installed option here as a safe and EFFECTIVE mod.
Many ppl think that since it's only wires, anyone can do it, which is the reason that there are so many building kits in their basements and selling on E-Bay. If they do a reasonable job and select good grounding points (usually pirated from other ppl's efforts), they can work.
Old Dec 31, 2003 | 09:51 AM
cato's Avatar
SouthernComfort Moderator
OK, the 8th wire you are referring to is my creation. It is
different from Gordon's #8. The wire you refer to connects
a factory ground on the fender in the brake booster area to
the end of Gordon's wire connected to the drivers side strut
tower. I was poking around looking for more factory grounds
and found 3 that Gordon did not connect to. 1 next to the
windshield washer tank, 1 next to the battery under the battery
cover and the third in the break booster area on the fender.
2003 Twilight Blue 5AT Sedan, sunroof,
Graphite Leather, splashguards,
12 wire Hyper-grounding kit,
350Z intake duct, Stillen Hi-Flow Airbox
Underbody rear diffusers, Drilled aluminum pedals
Old Dec 31, 2003 | 06:13 PM
Gordgee's Avatar
Administrator
Whoops, sorry Cato. 12 Wire Hyper-Grounded G35, not 11. Officially makes the Cato-GroundingGear setup the most grounded G35 on the planet that I've heard of![img]/w3timages/icons/laugh.gif[/img]
Now, if I could just figure out what they're supposed to do, I'd try them myself!
Old Jan 1, 2004 | 06:05 PM
KAHBOOM's Avatar
How would one get to the transmission housing.. It seems like it would be really tight back there
<font color=black> Black/Willow Coupe </font color=black>
Premium Package
18" Tire/Wheel Package
K&N Filter, Z-Tube, EGK
Old Jan 3, 2004 | 04:10 PM
waijai's Avatar
i.love.gold
Jack up the car...go from underneath right behind the passenger side front wheel.
Ivory Pearl coupe
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
twentyeggs
Sep 11, 2015 03:58 PM
mtlruss
Lighting
Sep 9, 2015 07:44 PM
