need help
Old May 24, 2007 | 11:03 PM
805g's Avatar
need help
finding a diy for UD pulley sets. i've used the search and old pics don't work and i can't find acomplete thread.
also i need a diy for a plenum spacer, again, can't find any pics with a diy.
Thanks all
Old May 24, 2007 | 11:49 PM
Andy2434's Avatar
Here, allow me to relocate this for you. I am sure that someone will have some informative info for you. Good luck!
Old May 25, 2007 | 03:57 PM
805g's Avatar
bump, anyone?
Old May 25, 2007 | 03:59 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
doing an underdrive pully yourself is not a good idea. I work in a shop and still needed my service managers help to get the stock drive pulley off and the new one on. It's not fun, leave it to the pro's.
-GP-
Old May 25, 2007 | 04:27 PM
joe603's Avatar
You also need a special tool...if your mechanically inclined, go ahead! Autozone rents tools if you need it.
Old May 25, 2007 | 04:33 PM
805g's Avatar
WHAT TOOL!?!?!?!
also, i have a toyota tech as a buddy, he is usually quite capable but i'm sure he won't have this special tool so i'll need to know what it is.
Thanks so much.
Old May 25, 2007 | 04:48 PM
ttrank's Avatar
Grocery getter
UR should have instructions on their site.
Old May 25, 2007 | 04:54 PM
805g's Avatar
thanks ttrank
Old May 25, 2007 | 05:00 PM
805g's Avatar
according to their site it says
• Loosen the crankshaft pulley bolt but do not remove yet.
- Manual Transmission: Have helper put car in 6th gear and hold the brake pedal firmly, the bolt is very tight and will require significant force to loosen.
A ¾” impact gun is the easiest method of removal.
....don't we all have an impact. HAHAHAHA
i bet not, but i do!
