Coolant on belts
Old Jun 13, 2007 | 05:20 PM
805g's Avatar
Coolant on belts
installing my ur pulley set i got coolant on my new belts. They squeak like a motherf'er when i start up the g in the morning. The squeal goes until i am able to release the clutch entirely in a gear.
Any advice?
Old Jun 13, 2007 | 06:31 PM
sharif@forged's Avatar
If the squeal persists, than you probably need to tighen up your belts slightly.
Old Jun 13, 2007 | 06:39 PM
ttrank's Avatar
Grocery getter
Did you replace the belts with the pulleys? New belts will stretch out a little and may need re-tightened.
Old Jun 14, 2007 | 04:02 PM
805g's Avatar
how would one measure the correct tightness of the belts? when should i stop tightening?
Old Jun 16, 2007 | 01:14 AM
805g's Avatar
bump anyone know?
Old Jun 18, 2007 | 10:14 PM
g35ATX's Avatar
I always measure with my hand. They have some skind of tool to measure it.
Old Jun 20, 2007 | 09:34 PM
DriftDreamzSS's Avatar
Stop tightening when it takes moderate pressure to get 1/2" movent in the belt. Like it feels tight if you lightly push on it but if you push a little harder you can get a small amount of movment. If it still makes noise put on a some belt dressing, the paste kind that looks like never seize works better than the aerosol spray kind.
Old Jun 20, 2007 | 10:11 PM
Tonys-G's Avatar
I had the same thing after installing the supercharger I got coolant on the AC belt which was th eonly one left that hadn't been replace
well that thing sqeeled like a skinned cat, I did try tightneing it but didn't help!
I just got a new belt and replaced it and havn't had a problem since
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
BradMD_96
Oct 6, 2015 09:31 AM
Usman Ali
Sep 22, 2015 06:59 AM
reaper76
Sep 20, 2015 11:59 AM
AuAltima3.5
Cooling
Sep 13, 2015 10:46 AM
